| New Reply |
Moment of Inertia Experiment |
Share Thread | Thread Tools |
| May15-12, 09:33 PM | #1 |
In my experiment based on the inertia the angular velocity or speed goes either up or down with the angular momentum remaining the same. I understand that when a person is rotating to change the inertia you would either extend or detract the arms and legs (think dancer). I understand this concept and even somewhat how the calculate it except my angular momentum.
L=Iw since my inertia is changing how do I find the changing w(angular momentum) if I don't know the value of the L(angular momentum) yet. Would I just physically count the number of rotations per second in radians for each time the inertia is changed? |
| May16-12, 06:22 AM | #2 |
Hi welcome to phy forum(everyone does that so i did it too for your first post)
Well you dont know the L now but i hope that you know the speed at which the dancer is expanding her/his arms(& her mass and her arms mass....etc). So you will calculate L(t) as a function output of time and you must know both L & w at some instant (maybe before after she moves her arms)simultaneously, this way you will know w(t). NOOOOOOOO! dont count the number of rotation per second, I have no grudge over counting but it will give an average w over a time of 1 sec, which will be hazardous if w is not constant. |
| May16-12, 06:32 AM | #3 |
himassb! welcome to pf!
![]() the only convenient way i can think of is to transfer all the angular momentum to a "reference" body what exactly is your experimental set-up? |
| New Reply |
| Thread Tools | |
Similar Threads for: Moment of Inertia Experiment
| Finding dimensions of a beam using shear, moment, and moment of Inertia | Engineering, Comp Sci, & Technology Homework | 4 | ||
| Load Inertia - Mass Moment of Inertia Question | Mechanical Engineering | 2 | ||
| what tis hte difference betweeen mass moment of inertia and inertia | Classical Physics | 11 | ||
| Second Moment of Inertia - Area Moment of Inertia | Classical Physics | 1 | ||
| What are moment of inertia, mass moment of inertia, and radius of gyration? | Introductory Physics Homework | 1 | ||
