Maximum moments in 2-span beams
The discussion revolves around calculating the maximum moments in a 2-span continuous beam subjected to different uniformly distributed loads (UDL). Participants explore methods for analyzing this statically indeterminate structure, including the Moment Distribution method and the force method.
  • Homework-related
  • One participant seeks a method to calculate maximum moments in a 2-span beam, noting its statically indeterminate nature and the challenge of using equilibrium equations.
  • Another participant suggests looking into the force method and mentions the availability of tables with moment diagrams for such beams.
  • A different approach is proposed, treating each span as a propped cantilever and calculating end moments at the center support using the formula q*L*L/8.
  • One participant notes that averaging the end moments at the center support yields a result very close to the correct answer, which might be used in practice.
  • Clarification is provided regarding the averaging of end moments, with a caution that this method may not be strictly correct for unequal spans and loads, introducing the concept of stiffness and distribution factors.
  • A participant emphasizes the need to determine reactions at the end supports to fully construct the bending moment diagram.
Participants express various methods and approaches to the problem, but there is no consensus on a single correct method for calculating the maximum moments, indicating multiple competing views remain.
Participants highlight limitations related to unequal spans and loads, as well as the need for additional calculations to fully understand the bending moment distribution.
danyjr
1. How do you calculate the maximum moments in a 2-span continuous beam?
2 span beam with 2 different uniformly distributed loads (UDL) at different spans:
i46.tinypic.com/2d7zpw.jpg
I am a first year civil engineering student. This is apparently a statically indeterminate structure with one redundancy so I can't solve the problem using equilibrium equations.
I have seen a method called Moment Distribution but the examples seem to be available for 3 spans or more. Is there any simple way to find maximum bending moment in the beam?
Thanks in advance.
You mean, a statically indeterminate structure. You should look into the force method for this. Depends on what you need, I think you may also find tables with moment diagrams for such beams.
Taking each span as a propped cantilever, the end moment at the centre support with a udl would be q*L*L/8. The difference between the moments at the centre support is then redistributed in proportion to the stiffnesses of the two beams. That is, moment distribution with just one release. You should be able to adapt from an example with three spans.
I notice that if you average the end moments (at the centre) in this case, the correct answer is very close (<0.3%) to that, and is what an engineer might use in practice
Hi and thanks for responses.
Do you mean average the end moments (at centre support) ie M1=(q*L^2)/8 from the left hand span and M2=(q*L^2)/8 from right hand span?
(M1+M2)/2 = Max bending moment in the whole span
Correct?
That is what I meant, although it is not strictly correct for unequal spans and unequal udl's. Then stiffness K1 of left hand span is 1/L1. Hence k2 also. Then distribution factors DF's are k1/(k1+k2) and k2/(k1+k2) (The DF's should add up to 1). The moment at the centre is the maximum moment in the beam, but not as a matter of principle. To get the full bending moment diagram you need to take your final centre moment and use it (with the other loads) to find the reactions at the end supports. Then you can find the M at any section in the beam and draw the M diagram.
Thank you!
10K
17K
10K
