What does this paragraph mean?
  • Context: Undergrad
  • Thread starter Thread starter M. next
    Mean
The discussion revolves around the conservation of angular momentum in systems influenced by external conservative fields with spherical symmetry. Participants explore the implications of potential energy depending solely on the radial coordinate and how this affects angular motion.
  • Some participants note that angular momentum components are conserved in systems with spherical symmetry where forces are radial, indicating that potential energy depends only on the radial coordinate.
  • One participant provides an example of a planet orbiting the Sun, suggesting that the angular momentum remains constant due to the spherically symmetric nature of gravitational potential energy.
  • A later reply elaborates on the concept using Lagrangian mechanics, stating that the angular degree of freedom is cyclic, implying that if no forces act on it, there will be no change in that degree of freedom.
  • Another participant emphasizes the relationship between force and potential energy, arguing that if potential energy is solely a function of the radial coordinate, changes in the angular coordinate do not affect potential energy, leading to the absence of angular forces.
Participants generally agree on the conservation of angular momentum in the described systems, but there are varying levels of detail and interpretation regarding the implications of potential energy and forces acting on angular coordinates.
The discussion includes assumptions about the nature of forces and potential energy, particularly the dependence on radial coordinates, which may not be universally applicable in all contexts.
M. next
Components of angular momentum are also conserved in the case of a system evolving in an external conservative field with spherical symmetry where the resultant of all forces is radial i.e potential energy of the system depends only on radial coordinate.
For example, if you have a planet orbiting the Sun (assume the Sun is stationary), then angular momentum of the planet is constant, since the potential energy of gravity is only a function of the distance from the Sun (i.e., it is spherically symmetric).
Thanks. that was short and to the point.
in lagrangian langange it's saying that the angular degree of freedom is cyclic
in physics language it's saying that if there's no force acting on the angular degree of freedom then nothing about the angular degree of freddom will change
remember that force = gradient . potential energy, if the potential energy only depends on the radial coordinate then any change in the angular coordinate will make no change in the potential energy, so there is no 'angular forces'.
  • · Replies 30 ·
