Something weird with the fundamental theorem of calculus
The discussion revolves around the application of the Fundamental Theorem of Calculus (FTC) and the implications of integrating by parts for a function G that is infinitely differentiable on a closed interval [a,b]. Participants explore the consequences of assuming that all derivatives of G vanish at the endpoint b and the resulting estimates involving absolute values of integrals.
  • Some participants discuss the application of the FTC, noting that for any z in [a,b], the integral from z to b of G'(w) equals G(b) - G(z).
  • There is a proposal that integrating by parts leads to an expression involving G'(b) and an integral of G''(w), but some participants challenge the correctness of this integration by parts step.
  • One participant expresses confusion over the integration by parts process and the resulting terms, questioning the validity of the expressions derived.
  • Another participant points out that the estimate involving absolute values of integrals only holds when the lower limit is less than the upper limit, suggesting that the original application was incorrect.
  • Some participants argue about the implications of taking absolute values and switching limits in integrals, with differing interpretations of the results.
  • A participant raises a hypothetical question about the consequences of repeatedly applying integration by parts, speculating on the behavior of the function G as derivatives vanish.
Participants express disagreement regarding the application of integration by parts and the validity of the resulting expressions. There is no consensus on the correctness of the initial claims or the implications of the estimates derived from the integrals.
Participants note that the assumptions regarding the behavior of G and its derivatives at the endpoints are crucial to the discussion. The limitations of the estimates and the conditions under which they hold are also highlighted, particularly concerning the order of integration limits.
AxiomOfChoice
Suppose I know my function G is infinitely differentiable on the closed interval [a,b] and that all derivatives of G (including G itself) vanish at b. For any z in [a,b], I have by the FTC that
[tex] \int_z^b G'(w) dw = G(b) - G(z).[/tex]
Or, switching limits,
[tex] \int_b^z G'(w) dw = G(z) - G(b).[/tex]
One can integrate by parts on the left-hand side and obtain (this is basically what the integral remainder form of Taylor's theorem tells you)
[tex] G(z) - G(b) = G'(b)(z-b) + \int_b^z (z-w)G''(w)dw,[/tex]
or [itex]G(z) = \int_b^z (z-w)G''(w)dw[/itex] when you drop the terms that are zero (i.e., G(b) and G'(b)). Now, I want to take absolute values of both sides and do some estimating. I get
[tex] |G(z)| \leq \int_b^z |z-w||G''(w)|dw \leq C \int_b^z |z-w|dw,[/tex]
since we are assuming G is [itex]C^\infty[/itex] and therefore has bounded second derivative on [itex][z,b][/itex]. But on this interval, w > z, so |z-w| = w-z, so we have
[tex] |G(z)| \leq C \int_b^z (w-z) dw,[/tex]
which evaluates to
[tex] |G(z)| \leq - \frac 12 C (z-b)^2,[/tex]
which is telling me that a positive quantity is less than, or equal to, a negative number! What on Earth have I done wrong here?
I don't see this. I come up with
[itex]G'(z)z - \int_b^z G''(\omega)\omega \mathrm{d}\omega[/itex]
Here: putting [itex]\,\,u = G'\Longrightarrow u'=G''\,\,,\,\,v'=1\Longrightarrow v=w\,\,[/itex] , integrating by parts gives [tex]wG'(w)\left.\right]_b^z-\int_b^zwG''(w)dw[/tex] I don't understand why you got [itex]\,(z-w)\,[/itex] in the right integral and also [itex]\,G'(b)(z-b)\,[/itex] instead of
[itex]\,zG'(z)-bG'(b)[/itex]...?
which evaluates to
DonAntonio
The estimate that [itex]\left\vert \int_{a}^{b} f(x)\ \mathrm{d}x\right\vert \leq \int_{a}^{b} \vert f(x) \vert \ \mathrm{d}x[/itex] only applies when a<b. You applied it to an integral where the lower limit is greater than the upper limit.
Citan Uzuki said:
The estimate that [itex]\int_{a}^{b} f(x)\ \mathrm{d}x \leq \int_{a}^{b} \vert f(x) \vert \ \mathrm{d}x[/itex] only applies when a<b. You applied it to an integral where the lower limit is greater than the upper limit.
He didn't do this: he applied absolute value to both sides...
DonAntonio
Sorry, that was a typo. Should be fixed now.
I see, but it still is correct, as (assuming the function [itex]\,f\,[/itex] is positive on [a,b] , [itex]\,a<b\,[/itex] ) : [tex]\left|\int_b^a fdx\right|=\left|-\int_a^bfdx\right|=\int_a^bfdx= \int_a^b|f|dx[/tex] and if the function's negative on that interval then [tex]\left|\int_b^a fdx\right|=\left|-\int_a^bfdx\right|=\left|\int_a^b(-f)dx\right|= \int_a^b(-f)dx=\int_a^b|f|dx[/tex] so for a general function with changes of sign in [a,b] we have the same inequality.
DonAntonio
If one let's [itex]v = w - z[/itex], you still get [itex]dv = dw[/itex] as desired, but you also get what I wrote out. I'm allowed to do this, right?
This makes a lot of sense to me. I'm still trying to hash out DonAntonio's objection to this statement, but it seems right.
DonAntonio
I don't think this is true. Consider [itex]f(x) = 1[/itex] on the interval [itex][0,1][/itex]. We have
[tex] \left| \int_1^0 1 \cdot dx \right| = | 0 - 1| = 1.[/tex]
Whereas
[tex] \int_1^0 |1| dx = 0 - 1 = -1 \not \geq 1.[/tex]
So I think Citan is right.
His objection was that Citan Uzuki had originally written
[tex]\int_a^b f(x)dx\le \int_a^b |f(x)|dx[/tex]
rather than
[tex]\left|\int_a^b f(x)dx\right| \le \int_a^b |f(x)|dx[/tex]
to which he changed it after DonAntonio's post.
Choosing an additional constant doesn't change the integration by parts, as it will cancel out. I illustrate with the constant [itex]z[/itex] but it's true for any constant.
[tex]\int_b^z G'(w)dw = G'(w)(w-z)|_b^z - \int_b^z G''(w)(w-z) = 0 - \int_b^z G''(w)wdw + z\int_b^z G''(w) = zG'(w)_b^z - \int_b^z G''(w)wdw = zG'(z) - \int_b^z G''(w)wdw[/tex]
I think you're both right (theorem4.5.9 and AxiomOfChoice). Both results seem to be true, but the OP chose to write it with (w-z) in the integral (so he integrated by parts with z-b instead of just z). theorem's result doesn't contradict Axiom's answer, it simply doesn't lead to the same place as he wants. The mistake is what Citan mentioned: when he took absolute value of both sides, he didn't switch the bounds (from b--->z to z---->b), which of course gave a negative number.
(Just out of curiosity, what happens if we continue this integration by parts process as many times as we want? Won't it tell us that g(x) = 0 since each derivative vanishes as b and therefore the u(x)v(x) part will always cancel and we'll remain only with the integrals each time...? I know this is wrong but has anyone tried?)
I wasn't sure how axiom arrived at his integration by parts, though he cleared that up. My point was to show the equivalence of the two. The answer to his question had already been shared at that point.
You're right that the ##u(x)v(x)## is always zero, but the integral never goes away. Furthermore, there are not any precise bounds on the derivatives of ##G##, so we cannot make the integral small.
