Fourier Cosine Series Coefficient Calculation: A_n = (2)(-1)^{n+1}(n≥1)
The discussion revolves around the calculation of Fourier cosine series coefficients, specifically the A_n coefficients for a piecewise function defined over the interval from -2 to 2. The original poster attempts to derive the coefficients and compares their results with those from a textbook, noting discrepancies.
  • Participants discuss the process of extending the series and calculating the coefficients, questioning the correctness of their results compared to the textbook. There are considerations about the function's evenness and the implications of the piecewise definition on the Fourier series.
Participants are actively exploring the differences between their calculations and the textbook's results. Some guidance has been offered regarding the nature of the function and its extension, but no consensus has been reached on the correct approach or resolution of the discrepancies.
There is mention of potential normalization conventions in the textbook's answer and the need to clarify the values of the function in certain intervals. The original poster expresses uncertainty about whether they have omitted terms that should be included in their calculations.
TranscendArcu
So after I have properly extended the series, I want to find the A_n coefficients. In the case of A_0 I get 1/2 -- good, great. That's what the book gets.
Now for the general A_n:
[itex]A_n = \frac{1}{2} \int^2_{-2} (1)cos(\frac{n\pi x}{2}) dx[/itex]
because, in the piecewise function, the portions from -2 to -1 and from 1 to 2 are zero, we can just write this as
[itex]A_n = \frac{1}{2} \int^1_{-1} (1)cos(\frac{n\pi x}{2}) dx[/itex]
[itex]= \frac{1}{2}(\frac{2}{n\pi} sin(\frac{n\pi x}{2}) |^1_{-1} = \frac{2}{n\pi} sin(\frac{n\pi}{2}) n ≥ 1[/itex]
and because integers n's will just cause the sin term to alternate between -1 and 1:
[itex]= \frac{(2)(-1)^{n+1}}{n\pi} n≥1[/itex], and this is my general term for the coefficients. But this isn't what the book gets, so what have I done wrong?
If the period is 4, we need to know the values of f(x) between x = 2 and x = 4 (or, perhaps, between x = -2 and x = 0). What are those values?
RGV
Since it says to use a cosine series, I presume that the question intends for us to use an "even" function extension for the piecewise. Thus, the values for f(x) = 0 between -2<x<-1 and f(x) = 1 for -1 < x < 0. Assigning f(x)'s extension in such a way makes the function even and thus permits us to find a cosine series.
OK, that seems fair. You say your answer differs from that in the book. What is the book's answer? Is it, perhaps, just a matter of some different normalization convention? I don't see anything obviously wrong with your computation.
RGV
This is the books answer:
my answer will be [itex]f(x) = \frac{1}{2} + \sum_{n=1}^∞ ( \frac{(2)(-1)^{n+1}}{n\pi}) cos(\frac{n\pi x}{2})[/itex]
But they seem to think that we're skipping some terms (hence the 2n - 1 things), but I don't have any terms zeroing so I don't need to make that adjustment.
So I just tried to plot the first couple of terms in the series in MATLAB. I've attached the resulting graph in this post. As you can see, my answer isn't doing the right thing -- it's not correctly approximating the solution. Now, granted, this is only seven terms, but it doesn't seem to be doing very well. So I'm thinking that I must have a mistake somewhere in this work...
For even n ≥ 2 we will have [itex]\int_{-1}^1 \cos(n \pi x /2)\, dx = 0[/itex] because in each interval (-1,0) and (0,1) the positive and negative areas cancel. For example, when n = 2 the areas from x = 0 to x = 1/2 and x = 1/2 to x = 1 are opposite.
RGV
  • · Replies 16 ·
