New Reply
Springs: Speed when released & distance traveled.
Share Thread Thread Tools
May19-12, 08:31 AM   #1
Question:
A 1.6 kg block is pushed into a spring with spring constant of 1.0 x 10^3 N/m. The spring is compressed a distance of 2.0 cm [0.02m], and the block is released from rest in the horizontal direction.
(a) Calculate the speed of the block as it passes through the equilibrium position at x = 0, if the surface is frictionless.
(b) How far does the block travel before coming to rest? Assume a constant friction force of 4.0 N and the same initial conditions as before.
Formula I used for (a)
v = √[k/m (A^2 - x^2)]
v = √[1000/1.6 (0.02^2 - 0^2)]
v = 0.5m/s
Not sure about (a), But I have no clue as to (b)..
Should I used the work formula?
Work (J) = Force x distance
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
May19-12, 09:19 AM   #2
Part a is correct.
Hint: Use Newton's second law followed by kinematic equation relating velocity, acceleration, and distance. Or use work energy relationship.
May19-12, 09:23 AM   #3
This should work for (b):
Conserving energy:
(1/2)×k x2 = f * d
where, k is spring constant, x is the compression of the spring, f is the frictional force, d is the distance traveled by the block before coming to a halt.
May20-12, 07:55 AM   #4
Quote by AudioFlux View Post
Conserving energy:
(1/2)×k x2 = f * d
This gave me the same result [5cm, 0.05m] as one of the ways I tried it originally:
[v^2 = u^2 + 2ad]
Where:
a = F/m = 4N / 1.6kg = 2.5ms^-2
v = 0.5ms^-1
u = 0ms^-1
(0.5)^2 = (0) + 2 (2.5) d
0.25 = 5d
d = 0.25/5
d = 0.05m [5cm]
Your method:
(1/2)×k x^2 = Ff * d
Where:
Ff = 4N
k = 1000
x = 0.02
(1/2)× (1000) (0.02^2) = 4 * d
500 x 0.0004 = 4 * d
0.2 = 4 * d
d = 0.2 / 4
d = 0.05m [5cm]
May20-12, 09:35 AM   #5
Quote by Bradyns View Post
[v^2 = u^2 + 2ad]
Where:
v = 0.5ms^-1
u = 0ms^-1
0.25 = 5d
d = 0.25/5
d = 0.05m [5cm]
firstly, you put incorrect values into the formula v2=u2+2ad
v is the final velocity, u is the initial velocity. the final velocity has to be 0, as the block stops due to frictional force. secondly, you have taken the velocity that you obtained from (a), which is the velocity of the block if frictional force was not acting. also, the acceleration should be negative, because the block is decelerating due to the frictional force. also,
d = 0.25/5
d = 0.05m [5cm]
if you want to get the answer using your method, first find the velocity of the block where it leaves the spring, you can do this using energy conservation. now you can apply v2=u2+2ad
New Reply
Tags
distance, force, friction, spring, velocity
Thread Tools
Similar Threads for: Springs: Speed when released & distance traveled.
Thread Forum Replies
Finding average speed & distance traveled? Introductory Physics Homework 1
Average speed, and total distance traveled Introductory Physics Homework 2
Distance Traveled Introductory Physics Homework 5
Car's vibration after being compressed, and released on springs Introductory Physics Homework 2
distance traveled Introductory Physics Homework 1
