Powering a Railgun: Generating High Currents & Calculating Velocity
  • Thread starter Thread starter StickNinja
    Railgun
This discussion focuses on generating high currents for a railgun project using a 400F capacitor rated at 2.7V. The capacitor can store 1458J of energy, allowing for a discharge duration of approximately 1/29 of a second. The key challenge is achieving a discharge current of 150A, which can be calculated using Ohm's Law, considering the wire resistance and the capacitor's equivalent series resistance (ESR). The initial current will be 150A if the resistance is minimal, but will decay exponentially over time.
  • Understanding of Ohm's Law
  • Knowledge of capacitor specifications, including ESR
  • Familiarity with high-current applications
  • Basic principles of energy storage in capacitors
  • Research capacitor discharge characteristics and time constants
  • Learn about calculating equivalent series resistance (ESR) in capacitors
  • Explore high-current wiring techniques and materials
  • Investigate safety protocols for high-energy experiments
Electronics enthusiasts, hobbyists building high-current devices, and engineers interested in energy storage and discharge applications.
StickNinja
For fun I wanted to make a railgun, but I am having trouble figuring out how to generate a high current.
I have a 400F capacitor (only one, but it is suitable for my purposes).
It is rated at 2.7V
So the amount of energy it can store is 1458J, so it should be able to run the gun for 1/29 of a second
The problem I am having, is how do I generate the 150A?
Will it just run at 150A if it is allowed to discharge over 0 gauge wire (no other resistance is involved) or will it run at about about 1.4 amps if I am using 20ft of wire (maintaining 2.7 V)?
Capacitors have always confused me in this regard, any help explaining this would be appreciated.
At 150A, estimated velocity of a .1 gram object is 62 meters a second for this poject
StickNinja
The capacitor voltage and current will decay exponentially. Start with ohm's law: if you discharge 2.7V with .018 ohms, you will start off with 150A. Both V and I will then decay with a time constant of RC = 7.2sec.
Make sure to check dataheet of the supercap, particularly its ESR and max current spec.
We do not discuss dangerous activities here. It's all in the PF Rules, which everyone agreed to when they joined.
  • · Replies 61 ·
  • · Replies 26 ·
  • · Replies 19 ·
11K
9K
