Calculating the Unbalanced Force in a Pendulum System
  • Thread starter Thread starter krypt0nite
    Pendulum
The discussion revolves around calculating the magnitude of the unbalanced force acting on a pendulum bob when displaced from its equilibrium position. The problem involves a pendulum with a mass of 1.80 kg, a length of 1.25 m, and a displacement angle of 30.0 degrees from the vertical.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the calculation of the unbalanced force, including the relationship between tension, gravitational force, and centripetal force. There is uncertainty about how to correctly apply Newton's second law and the vector nature of the forces involved.
Some participants have provided calculations for speed and centripetal force, while others question the completeness of these calculations in relation to the unbalanced force. There is an ongoing exploration of how to properly account for all forces acting on the pendulum bob.
Participants are working under the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. The discussion includes varying interpretations of the forces at play and their components.
krypt0nite
I don't know how to calculate the magnitude of the unbalanced force.
A pendulum bob with a mass of 1.80 kg is displaced from its equilibrium position, A, to an unstable position, B, by means of a string which is kept horizontal. The force applied to the string is, F. The length of the pendulum is 1.25 m. The angle through which the pendulum is displaced is 30.0 degrees as measured from the vertical. Determine the following.
diagram
Draw a free body diagram for the pendulum bob when it is at an angle of 12.0 degrees as measured from the equilibrium position. Ca1culate the magnitude of the unbalanced force acting upon the bob. In what direction must the unbalanced force act?
I've calculated the speed which is 1.66m/s. And from the speed I've got the centripedal force which is 3.96N. I know the unbalanced force acts toward the center.
Ok, how do show how i calculated the unbalanced force.
I was thinking T- mg(cos something)= centripedal force but unsure of how and what to do next.
Careful. While there must be an centripetal force (which you calculated), it is only a component of the unbalanced (net) force. (If the unbalanced force only acted towards the center, then the speed of the pendulum would not change--it would just keep going in a circle--but you know it speeds up as it falls!)
First find the tension in the string by applying Newton's 2nd Law in the centripetal direction: [itex]T - mg cos\theta = ma_c = m v^2/r[/itex]. (Solve for T.)
There are two forces on the pendulum bob: the weight and the tension in the string. Add them (as vectors, of course) to find the net unbalanced force.
Does Fnet=5.4N 35 degrees above horizontal sound right?
Sounds good to me.
  • · Replies 16 ·
  • · Replies 27 ·
  • · Replies 21 ·
