| New Reply |
Work done by an ideal gas |
Share Thread |
| May22-12, 01:41 PM | #1 |
Could someone please prove why the work done by a gas is the area under a [itex] PV [/itex] diagram?
That is, I know that [itex] dW=P \text{ }dV[/itex], but why is that true physically? I realize that [itex] W=f \cdot d \text{ and } F=P \cdot A [/itex] .Thanks. |
| May22-12, 01:54 PM | #2 |
You have more or less done it for yourself!!
W = P x V......P = F/A and V = A x d W = F/A x A/d ....= F x d |
| May22-12, 01:57 PM | #3 |
Well yes, I know that the equation is true, but I was wondering why it's physically true. For example, the area under a velocity-time graph is displacement. Why is the area under the graph the work done?
| May22-12, 02:01 PM | #4 |
It is because the graph is of P against V so the area under this graph must be the PxV quantity.....which is Fxd = work done.
| May22-12, 02:03 PM | #5 |
Oh...wow I'm silly. Thanks!
| May22-12, 02:04 PM | #6 |
you are in good company!!
| May22-12, 03:55 PM | #7 |
Another way to say all this is that, you understand the area under the v vs. t curve is displacement x because you think of v as dx/dt. Thus, to understand why the area under a P vs. V curve is work done, you simply need to think of pressure as dW/dV, i.e., pressure is the amount of work done per unit volume change. In other words, instead of thinking of work as something that comes from pressure, think of pressure as a concept that stems directly from work. That is very much what pressure is-- the concept of the amount of work done per volume change. Indeed, there are situations where the easiest way to calculate pressure P is to first calculate the work W as a function of V and take dW/dV.
| May23-12, 12:57 PM | #8 |
just remember that this is true under the assumption of quasistatic conditions, which is almost static but notquite.
think about a situation where the internal pressure is much higher than the external presssure. how do you calculate work then? thafeera |
| May23-12, 01:22 PM | #9 |
Another little tip: look at the units of the quantities you are multiplying.
P x V units are Pa x m^3 = (N/m^2) x m^3 = Nm = energy units v x t units are ms^-1 x s = m = distance units F x e units N x m = energy units V x Q units are volts x charge = V x C = (J/C) x C = J = energy units |
| New Reply |
Similar discussions for: Work done by an ideal gas
| Work and ideal gases | Introductory Physics Homework | 4 | ||
| How does the ideal gas law work? | Chemistry | 1 | ||
| Ideal Gas Work | Classical Physics | 5 | ||
| Work done by an Ideal Gas | Biology, Chemistry & Other Homework | 1 | ||
| Work done by non-ideal gas | Introductory Physics Homework | 1 | ||
