New Reply
Density question
Share Thread Thread Tools
May24-12, 07:03 AM   #1
Density question
Hello,
I will be honest and upfront, I am truly no chemist and actually have no clue on what to do..
I am trying to adjust the density of water, making it more dense is easy by just adding several grams of salt.
But now here comes my problem, I need to make water less dense. The density I need is 0,94.
Now I could easly say I can use alcohol and mix it up.
But the fluid should be disposable trough the sewage and not dangerous. I am a little stuck on this...
Thanks in advance.
Edwin
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Researchers use light projector and single-pixel detectors to create 3-D images
>> GPS solution provides 3-minute tsunami alerts
>> Single-pixel power: Scientists make 3-D images without a camera
May25-12, 08:12 AM   #2
If you freeze water you get a density of .92 and mix with water in a slurry of ice/water to get the .94 density.
May25-12, 08:40 AM   #3
You can create a slurry of any less dense material with water and make it homogeneous (like milk and butterfat). Mud is a mixture of dirt and water with a density of more than 1.0.
May27-12, 07:51 AM   #4
Density question
You might also achieve your goal by simple aeration. The air or other gas can lower the effective density of the water.
New Reply
Tags
dense, density, water
Thread Tools
Similar Threads for: Density question
Thread Forum Replies
Density question. Introductory Physics Homework 14
work density / heat density question Introductory Physics Homework 1
Idrees Question is Easy haha Please help DENSITY question?? Introductory Physics Homework 1
Question about density Introductory Physics Homework 4
need some help regarding a density question Introductory Physics Homework 2
