Heat Transfer Capability of Substances
  • Context: High School
  • Thread starter Thread starter wasteofo2
    Heat Heat transfer
The discussion revolves around the terminology used to describe the ability of a substance to lose heat to its surroundings. Participants explore various concepts related to heat transfer mechanisms, including conduction, convection, and radiation, while seeking a common term that encapsulates this ability.
  • Jacob inquires about a common term for a substance's ability to lose heat.
  • Daniel suggests the "thermal convection coefficient" as a measure of heat exchange.
  • Another participant proposes "boundary thermal resistance" or "conductance" as relevant terms.
  • A different viewpoint introduces "emissivity" as a measure of radiation emitted by a surface.
  • Jacob expresses a desire for a simpler term, comparing heat loss to electrical conductivity and light reflectivity.
  • One participant humorously suggests that if something loses heat easily, it is simply "hot."
  • Another participant explains that heat loss occurs through conduction, convection, and radiation, detailing each mechanism.
  • Waste argues that there is no single common word for the ability to lose heat, summarizing the importance of various material properties under different conditions.
  • Waste elaborates on how emissivity relates to heat loss, emphasizing the role of temperature and surrounding conditions.
  • Jacob expresses appreciation for the term "emissive" as a suitable descriptor.
Participants do not reach a consensus on a single term to describe the ability to lose heat, with multiple competing views and terms proposed throughout the discussion.
Participants highlight that the effectiveness of heat loss depends on various factors, including temperature, surrounding medium, and specific material properties, indicating that no single term can universally apply.
wasteofo2
I was just wondering if there's a word to describe the ability of a substance to lose heat to it's surroundings.
Thanks,
Jacob
Science news on Phys.org
Well,a substance loses heat the very same way it gains,so there sould be a word for its (sic) ability to CHANGE heat with the surroundongs...
It's called THERMAL CONVECTION COEFFICIENT and it's regularly denoted by [itex]\alpha [/tex]<br /> It is the heat gave away/absorbed in one second by 1 sq.meter of a body's surface to drop/raise it temperature by one Kelvin.<br /> <br /> Browse the net for Newton's cooling law...<br /> <br /> Daniel.[/itex]
Not necessarily "convection". I use a boundary thermal resistance (resistivity) [tex]R_b_d[/tex], or the inverse : boundary thermal conductance (conductivity). Units are in K∙m2/W, (same as dextercioby). It represent thermal conductivity at an interface between two different mediums.
The question is a little vague, so I'll supply another word: Emissivity. Emissivity is the ratio of radiation emitted by a blackbody or a surface and the theoretical radiation predicted by Planck’s law. So a mirror has emissivity near 0, while lampblack has emissivity near 1.
This is way higher level stuff than I was thinking I'd get...
I'm not looking for anything as "fancy" as what you guy's are talking about, just something common.
For example, if something transfers electricity well, it's highly conductive. If something reflects light well, it's highly lusterous. If something loses heat easily, it's ______.
Thanks,
Jacob
..the opposite of reflective, as I said. You don't need a new concept.
I'd have said radiation, but the point is moot. There are other transfer mechanisms.
wasteofo2 said:
If something loses heat easily, ...
... it's hot!
I think the term "thermal conductance" which Gonzolo mentioned is the most appropriate.
Substances 'lose' heat, or rather heat is transferred by three mechanisms.
Conduction - phonon and electron conduction with the latter only significant at relatively high temperatures,
Convection - a liquid or gas phase conducts heat, which is enhanced by motion of the fluid, whether due to buoyant forces (e.g. natural convection) or forced convection.
Radiation - in which heat is radiated as photons.
Waste,
There is no "common" word that means "the ability of a body to lose heat". If there were some common term that were used to refer to the characteristic that determines the rate of heat loss, one might have fed that word to you, but as such, this word would not represent any particular property of the material. Others here have given you properties that are important in determining the ability to lose heat. Let me summarize (while I elaborate upon) their posts.
You want a material property which is responsible for heat loss. Different properties of the material are important under different circumstances.
At high temperatures (T>>T(ambient)), the dominant mechanism of heat loss is through radiation [Astronuc]. The rate of heat loss is proportional to [itex]\epsilon T^4[/itex], where [itex]\epsilon[/itex] is known as the emissivity [Krab] and T is the temperature [Gonzolo]. Blackbodies are considered perfect radators : [itex]\epsilon = 1[/itex]. The emissivity is reasonably correlated to the absorptance (A) of a material, which in turn is equal to 1-R, where R is the reflectance. So, in general, you can expect a good reflector (most things that are white or lustrous or just reflective) to be a poor emitter, and hence will lose heat slowly. A poor reflector (most things dark or black) will be a good absorber, and thus can be expected to lose heat rapidly[Krab]. This is as close as it's going to get, to your goal of finding a familiar explanation.
When the temperature is no so high, and especially if there air flow (or flow of any fluid, for that matter), then the rate of heat loss if proportional to [itex]hA\Delta T[/itex], where h is the convective heat-transfer coefficient [Dexter], A is the effective surface area, and [itex]\Delta T[/itex] is the temperature difference [Gonzolo]. This mechanism of cooling is known as (forced) convection [Astronuc]. The quantity h, is however, not so much a characteristic of the cooling object, as it is a characteristic of the surrounding medium (and is related to its thermal contact, flow rate, viscosity and other properties). So, the most important property of a body cooling convectively, is the effective surface area (hence the fins on radiators). Now, if you are interested in the rate of cooling, rather than the rate of heat loss, there is one more property involved. While these two terms appear synonymous, the latter refers to the amount of energy lost in time, while the former refers to the temperature change. The rate of decrease of temperature is inversely proportional to the specific heat capacity of the object. Water cools down slowly because of its large specific heat.
If your object is in contact with another solid or liquid, then the rate of heat loss of the hot body (conduction [Astronuc] becomes important) through conduction, depends on the thermal conductivities of both bodies, the heat capacity of the surrounding body, their geometries, the temperature difference, and the area and nature of contact. As far as geometry is concerned, it's hard to transfer heat through long and narrow sections. A good electrical conductor is usually a good thermal conductor (though the converse need not be true).
So, depending on the surroundings and the temperature of your object, you must determine which is the important property. But in most cases, a small, black sphere will lose heat pretty slowly while a shiny piece of wire mesh will lose heat much faster.
In short, no single word really, but if I had to pick one, I'd go with 'emissive'.
I like emissive (I'm a simple man :biggrin:), thanks all.
  • · Replies 18 ·
  • · Replies 17 ·
