Specular reflection from moving mirrors
  • Context: Graduate
  • Thread starter Thread starter erielb
    Mirrors Reflection
The discussion centers on the implications of a moving mirror on the law of specular reflection, specifically when the mirror translates parallel to its normal direction. Participants explore whether the angle of reflection remains equal to the angle of incidence under these conditions and consider the effects of the mirror's motion toward or away from a stationary light source, as well as the impact of constant versus varying mirror velocity.
  • One participant questions if the law of specular reflection holds for a translating mirror and asks about the effects of the mirror's motion relative to the light source.
  • Another participant suggests that transforming the system can yield a stationary mirror perspective, noting that if the mirror moves toward the light source, the angle relative to the normal decreases, while it increases if moving away.
  • A participant seeks clarification on the mathematical setup for the transformation and proposes a step-by-step approach to relate the outgoing angle to the incoming angle, considering the effects of the mirror's velocity.
  • Another participant agrees with the proposed method and adds that a frequency shift occurs due to the moving mirror.
Participants express varying levels of understanding and agreement on the mathematical approach to the problem, but there is no consensus on the implications of the mirror's motion on the angles of incidence and reflection or the overall validity of the law of reflection under these conditions.
The discussion includes assumptions about the nature of the light source and the mirror's motion, as well as the potential neglect of effects from acceleration in certain scenarios. The mathematical relationships proposed are contingent on specific conditions that may not be universally applicable.
erielb
Question:
Does the law of specular reflection (angle in = angle out) for obliquely incident light rays still hold if the mirror is translating in a direction parallel to its normal direction?
If not, what different effects attend said translation if
a) the motion is toward or away from the stationary light source, and
b) the mirror velocity is constant or varying?
Science news on Phys.org
You can transform the system to get a stationary mirror. If the mirror is moving towards the light source, the transformation reduces the angle relative to the normal vector of the mirror plane. The outgoing angle is then the same as the incoming one. A backtransformation reduces the angle a second time.
If the mirror is moving away, the angle is increasing.
You can look at the velocity at a certain time for the reflection angle at this time. Effects from acceleration are negligible, unless you have really unrealistic values for that.
Hey MFB!
Thanks for your reply, but I'm not sure how to diagrammatically set-up or mathematically carry out the transformation you're talking about.
Say the mirror is moving away from the light source (along the direction of it's normal with fixed velocity v) and the light ray is incident with angle "alpha" and speed c. If "beta" is the outgoing angle, what equation relates it to alpha?
Let me explain what I think you mean, then if I have it right, I'd appreciate you letting me know. Thanks again for your help.
1) break out the incoming light velocity c into its components parallel and perpendicular to the mirror surface using the product of c with the sine and cosine functions of angle alpha.
2) reduce the magnitude of perpendicular component of the incoming light velocity by subtracting the speed of the mirror v, i.e. c x cos[alpha] - v.
3) reflect the reduced perpendicular component and vectorally add the reversed perpendicular component to the original parallel component of the incoming ray to get the total reflected ray
4) calculate "beta" angle as pi/2 minus the arc tangent of the ratio {[(c x cosine alpha) -v]/ [c x sine alpha]}
5) since the magnitude of the reversed perpendicular component is in this instance less than the original perpendicular component, beta will have a larger value than alpha.
6) if the mirror were moving towards the light the whole analysis would result in a beta less than alpha.
Hope I'm right; thanks again, Eriel
I think this should work as you described it.
In addition, you get a frequency shift due to the moving mirror.
  • · Replies 19 ·
  • · Replies 26 ·
