Solar Sail Physics - Do they work on a large scale?
The discussion centers on the feasibility of using solar sails for large-scale space travel, specifically examining the acceleration required to move a 1 metric megaton starship with a 4 km² solar sail. Participants explore the implications of solar radiation pressure, the necessary sail area for desired acceleration, and the distance from the Sun at which solar sails remain effective.
  • Monica Mostly questions the acceleration achievable by a solar sail and its practicality for intrasystem travel, seeking rules of thumb for sail area relative to mass and distance from the Sun.
  • One participant notes that a metric megaton is a significant mass, suggesting that such a large object would not be effectively moved by a solar sail of the proposed size.
  • Another participant provides a formula for calculating the force on the sail based on solar luminosity and distance, indicating that a vast area of sail would be needed to achieve even minimal acceleration.
  • Concerns are raised about the realistic acceleration capabilities of solar sails, with one participant emphasizing that they are unlikely to provide sufficient thrust for rapid transit compared to other propulsion methods.
  • Participants engage in mathematical discussions, with some correcting each other’s calculations regarding the required sail area for specific accelerations.
Participants generally agree that solar sails would struggle to provide adequate acceleration for large masses, but there is no consensus on the exact calculations or the practicality of solar sails for such applications. Multiple competing views on the effectiveness and feasibility of solar sails remain present.
Limitations include assumptions about the mass of the sail, the efficiency of reflection, and the effects of distance from the Sun on solar radiation pressure. The discussion does not resolve the complexities of these factors.
monicamostly
Hello physicists! I'm hoping you can help me with a question I'm pondering for a book.
At what acceleration could a 4 km^2 solar sail move a 1 metric megaton starship? Assume we're using the solar radiation from the Sol system as our force and that the solar sail in questions is as low mass and highly reflective as theoretically possible.
Basically, I'm trying to understand if solar sail is an economical method of intrasystem travel in terms of time, not energy. How large would the solar sail have to be to move something that big at an acceleration of greater than 100 m/s^2? (Assume g-forces on the crew are not an issue.)
How far from the sun is too far for a solar sail to be useful? At what point does solar radiation become too weak to maintain a reasonable acceleration?
Are there any simple rules of thumb for this? (Can we invent them?) Such as 1 km^2 sail per X number of tons? X% decrease in acceleration per 1 AU from the sun? X% change in acceleration from solar radiation per X% change in the luminosity of the star compared to the Sun?
Any wisdom you can add would be helpful. Thanks!
-Monica Mostly
A metric megaton is a lot. That's 10^9 kg. That's the mass of a cube of water 1km across. What could you possibly need to move that is that massive? Trajectory of that mass would remain virtually unchanged with or without a 4km² sail.
Effect on solar sail is dominated by radiation pressure, which is easy enough to compute. At 100% reflectivity, you can get 2x the momentum carried by the light. So the maximum force on the sail is given by following expression.
[tex]F=\frac{A L}{2 \pi R^2 c}[/tex]
Where A is area of the sail, L is total luminosity of the Sun, R is the distance from the Sun's center, and c is the speed of light. Sun's luminosity is 3.846×1026W. So at Earth's orbit, R≈150Gm, the force comes out to 9N per square kilometer.
So to accelerate even a tiniest ship at 1G, you will need thousands of square kilometers of sail, made of material that adds up to considerably less than 1kg per square kilometer.
Hopefully, that answers all of your questions on time-efficiency of solar sails.
Welcome to PF!
In short, the acceleration for any realistic solar sail will be minuscule and not appropriate for short transit times.
Just to give you a rough idea what we are talking about the upper limit for the force obtainable. Since solar light has a power P = 1360 W/m2 at the Earths distance from the sun, you can expect a reaction force of F = 2*A*P/c for fully reflected light over an area of A (with c being the speed of light) which means that to give the mass m an acceleration a from this force you need an area of A = 2*m*a*c/P. To give m = 1 kg an acceleration of one G, a = 9.8 m/s2 you therefore need no less than 4.3 km2 of sail, and that is even with the very unrealistic assumption that the sail itself has no mass. Add solar sail mass and maneuvering that gives realistic interplanetary trajectories and you quickly realize that solar sails are not going to accelerate fast or "go" anywhere quick, at least not compared with other existing or feasible propulsion technologies.
You may want to read some more background material about solar sails on [1].
[1] http://en.wikipedia.org/wiki/Solar_sail
Filip, A=m*a*c/(2P) from your equations above, giving a little over 1km², which is the same result that I give in a post right above yours.
You are right. I managed to mess up moving a factor of 2 to the other side :rolleyes:
That's what I was afraid of. I was hoping I was doing the math wrong. Thanks everyone!
  • · Replies 21 ·
