New Reply
Wave Equation
Share Thread Thread Tools
May27-12, 08:34 PM   #1
Wave Equation
Consider an elastic string of length L whose ends are held fixed. The string is set in motion with no initial velocity from an initial position u(x, 0) = f (x). Assume that the parameter alpha = 1. Find the displacement u(x,t) for the given initial position f(x)
3. The attempt at a solution
[tex]
u(x,t) = X(x)T(t) \Rightarrow \frac{X''}{X} = \frac{T''}{T} = -\lambda\\
X = C_1 cos(\sqrt{\lambda}x) + C_2 sin(\sqrt{\lambda}x)\\X(0) = C_1 = 0\\X(L) = C_2 sin(\sqrt{\lambda}L) = 0 \Rightarrow \sqrt{\lambda}L = n\pi \forall n\geq 1 \Rightarrow \lambda = (\frac{n \pi}{L})^2\\
T''+ \lambda T = 0 \Rightarrow T = C_1 cos(\frac{n \pi t}{L}) + C_2 sin(\frac{n \pi t}{L})\\
\Rightarrow u_n(x,t) = A_n cos(\frac{n \pi t}{L})sin(\frac{n \pi x}{L}) + B_n sin(\frac{n \pi t}{L}) sin(\frac{n \pi x}{L})\\
\Rightarrow u(x,t) = \sum _1 ^\infty A_n cos(\frac{n \pi t}{L})sin(\frac{n \pi x}{L}) + B_n sin(\frac{n \pi t}{L}) sin(\frac{n \pi x}{L})\\
u(x,0) = 1 = \sum _1 ^\infty A_n cos(\frac{n \pi (0)}{L})sin(\frac{n \pi x}{L}) + B_n sin(\frac{n \pi (0)}{L}) sin(\frac{n \pi x}{L}) = \sum _1 ^\infty A_n sin(\frac{n \pi x}{L})\\
\frac{\partial u(x,0)}{\partial t} = \sum _1 ^\infty B_n \frac{n \pi}{L} sin(\frac{n \pi x}{L}) = 0\\
[/tex]
So this forces all of the B_n to zero. We now solve the A_n
[tex]
A_n = 2 \int _0 ^L f(x)sin(\frac{n \pi x}{L}) dx = 2 \int_{\frac{L}{2} - 1} ^{\frac{L}{2} + 1} sin(\frac{n \pi x}{L}) dx = \frac{4Lsin(\frac{n \pi}{2})sin(\frac{n \pi}{L} )}{\pi n}
[/tex]Thus, my solution should be:
[tex]
u(x,t) = \sum_1 ^\infty \frac{4Lsin(\frac{n \pi}{2})sin(\frac{n \pi}{L} )}{\pi n} sin(\frac{n \pi x}{L})cos(\frac{n \pi t}{L})
[/tex]
However, this answer is off by a factor of L from what the book has. Can anyone help me find my mistake?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
May27-12, 10:20 PM   #2
Everything looks good until evaluating that integral. You'll have to point us to which trig identity(s) you used to make it easier to check, but I'm suspicious of that factor of L in the same line that starts [itex]A_n=\dots[/itex]
May28-12, 05:47 PM   #3
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Quote by TranscendArcu View Post
[tex]
[/tex]
Doesn't the half-range expansion for ##A_n## look like this$$
A_n = \frac 2 L \int _0 ^L f(x)sin(\frac{n \pi x}{L}) dx$$
New Reply
Thread Tools
Similar Threads for: Wave Equation
Thread Forum Replies
Question on wave equation of plane wave. Classical Physics 3
I must use the wave equation to to find the speed of a wave. Introductory Physics Homework 3
Wave on a rope - question concerns the maths of the wave equation Introductory Physics Homework 3
wave equation, transverse wave Introductory Physics Homework 3
wave equation and graphing wave instance Advanced Physics Homework 0
