Register to reply
Adiabatic Wind
by EmBista
Tags: adiabatic, altitude, chinook, pressure, temp
Share this thread:
EmBista
#1
May28-12, 03:12 AM
P: 25
Adiabatic wind. The normal airflow over the Rocky Mountains is west to east. The air loses much of its moisture content and is chilled as it climbs the western side of the mountains. When it descends on the eastern side, the increase in pressure toward lower altitudes causes the temperature to increase. The flow, then called a chinook wind, can rapidly raise the air temperature at the base of the mountains. Assume that the air pressur p depends on altitude y according to [itex]p=p_0e[/itex]-ay where [itex]p_0=1.00atm[/itex] and [itex]a=1.16*10[/itex]-4m-1. Also assume that the ratio of the molar specific heats is: [itex]γ=4/3[/itex]. A parcel of air with an initial temperature of -5.00℃ descends adiabatically from [itex]y_1=4267m[/itex] to [itex]y=1567m[/itex]. What is its temperature at the end of the descent?
2. Relevant equations
pVγ=a constant
TVγ-1=a constant
3. The attempt at a solution
I really don't know if I went right here.. but here it goes.
[itex]p_1=1*e^{-a*4267}[/itex]
[itex]p_1=0.609587975[/itex]
[itex]p_2=1*e^{-a*4267}[/itex]
[itex]p_2=0.833791423[/itex]
[itex]p_1V_1^γ=p_2V_2^γ[/itex]
[itex]V_2^γ=(p_1/p_2)[/itex] as [itex]v_1^γ=1[/itex]
[itex]ln(V_2)=(ln(p_1/p_2))/γ[/itex]
[itex]e^{ln(V_2)}=e^{ln(p_1/p_2)/γ}[/itex]
plug in all the numbers and [itex]V_2=0.790455348[/itex]
[itex]T_2V_2^{γ-1}=T_1V_1^{γ-1}[/itex]
[itex]V_1=1[/itex] [itex]V_2=0.790455348[/itex] [itex]T_1=-5[/itex] [itex]T_2=?[/itex]
[itex]T_2=\frac{T_1V_1^{γ-1}}{V_2^{γ-1}}[/itex] as [itex]V_1^{γ-1}=1[/itex]
[itex]T_2=\frac{T_1}{V_2^{γ-1}}[/itex]
[itex]T_2=\frac{-5}{0.790455348^{4/3-1}}[/itex]
[itex]T_2=-5.40767883[/itex]
This answer doesn't make sense because the temperature is supposed to INCREASE.
So can anybody tell me where I went wrong? Maybe tell me I used the wrong formulas..
Thank you :)
Phys.Org News Partner Science news on Phys.org
FIXD tells car drivers via smartphone what is wrong
Team pioneers strategy for creating new materials
Team defines new biodiversity metric
gneill
#2
May28-12, 07:53 AM
Mentor
P: 11,685
Try it using the Kelvin scale.
EmBista
#3
May28-12, 07:01 PM
P: 25
That solved it :) wow i'm an idiot
Register to reply
Related Discussions
Wind Waves in Reservoir ~ Wind run-up and Wind set-up Earth 10
Wind scaling and increasing wind speed for wind tunnel problem Mechanical Engineering 3
Wind Power Vehicle Traveling Down Wind Faster Than The Wind General Physics 305
Determine the Electric Power Produced by a Wind Turbine Over a Range of Wind Speeds Advanced Physics Homework 5
Wind vs relative wind (A Thermdynamics and aerodynamics issue) Classical Physics 15
