Uncovering the Speed of a Leap: Salmon's 3.56m Jump
  • Thread starter Thread starter sundrops
    Jump Speed
The discussion centers on calculating the speed of a salmon's jump, which reaches a height of 3.56 meters. The initial vertical velocity (Vyo) required for this jump is determined using the equation (Vy)^2 = (Vyo)^2 - 2g(y - yo). The correct calculation yields Vyo = 8.35 m/s, but the user questions the accuracy of this result. The key to solving the problem lies in understanding the relationship between vertical velocity, acceleration due to gravity (9.8 m/s²), and maximum height.
  • Understanding of kinematic equations in physics
  • Knowledge of projectile motion and vector components
  • Familiarity with gravitational acceleration (9.8 m/s²)
  • Ability to solve simultaneous equations
  • Review kinematic equations for vertical motion
  • Study vector decomposition in projectile motion
  • Practice solving simultaneous equations in physics problems
  • Explore real-world applications of projectile motion in biology
Students studying physics, educators teaching kinematics, and anyone interested in the biomechanics of animal movement.
sundrops
Salmon swimming up a river to their spawning grounds, leap over all sorts of obtacles. The unofficial salmon-altitude record is a 3.56m jump. Assuming that the salmon took off at a 45 degree angle, what was the speed at which it was emerging from the water?
Xo = 0m
Yo = 0m
Y = 3.56m
a = 9.8m/s^2
X = ?
v = ?
and I thought of using this formula : Y = Yo + VYo(t) + (0.5)(a)(t)^2
but I couldn't because I don't have t.
Hint: it's a 45 degree angle, so you should see from a vector diagram that initially v_x = v_y. Calculate the initial vertical velocity required for it to reach a max height of 3.56 metres, and then use that (v0y) to get v0.
Big Hint...if the fish doesn't go any higher than 3.56 metres, then obviously its final velocity (what you have called v) is zero. So now, you want to find the change in vertical velocity. You know the vertical acceleration. You know the maximum height reached. The two unknowns are therefore v0y and t. If you also use the equation v = v0y +at...then you have two equations and two unknowns. The problem is finished.
here's what i did for this problem:
0 = (Vyo)^2 - 2(9.8m/s^2)(3.5m-0m)
Vyo = 8.35m/s
my answer was incorrect however, I was wondering where I went wrong...
13K
