Calculating Force on Cushioned Legs from Dropped Mass
  • Thread starter Thread starter btbam91
    Force Mass
The discussion focuses on calculating the impact force on cushioned legs of a platform when a mass m is dropped from a height h. The analysis utilizes energy conservation principles to determine the maximum velocity just before impact, leading to the formula |F| = (0.25)*(m*sqrt(2gh))/t for the force on each leg. The net force acting on each leg is derived from the impulse-momentum theorem, confirming the calculations align with Newton's second law. The importance of distinguishing between net force, weight, and normal force is also emphasized.
  • Understanding of Newton's Second Law
  • Familiarity with energy conservation principles
  • Basic knowledge of impulse and momentum
  • Mathematical proficiency in algebra and square root calculations
  • Study the derivation of impulse-momentum theorem in physics
  • Explore energy conservation in mechanical systems
  • Investigate the effects of damping in cushioned systems
  • Learn about normal force and weight distribution in static and dynamic scenarios
Physics students, mechanical engineers, and anyone involved in designing impact-absorbing structures or systems.
btbam91
Say we have a platform with 4 legs attached. Attached to each leg is a small cushion.
If we drop our object of mass m a distance h, the small cushions compress completely in time t.
So we have variables: m,h,t
My analysis went has follows:
1. Energy conservation to find the max velocity the instant before our object hits the ground.
mgh = (1/2)mv^2
v = sqrt(2gh)
2. To find the impact force, set impulse equal to the change in momentum.
J = mv2 - mv1 = F*t
v2 = 0 because our object will stop when it is fully compressed, and v1 is the velocity calculated earlier.
F*t = -m*sqrt(2gh)
|F| = (m*sqrt(2gh))/t
3. In order to find the force in each leg...
Is this correct?
Thanks for the help!
Is this correct?
Assuming that the object of mass m is dropped on the dead center of the platform, the force you are calculating by your formula is the NET force acting on each leg. This is always true when using Newtons 2nd law. You might want to separate out the weight and normal force acting on the leg.
  • · Replies 38 ·
  • · Replies 21 ·
  • · Replies 30 ·
  • · Replies 27 ·
