Question: Understanding Fluid Pressure and Its Relation to Flow Speed
The discussion revolves around the relationship between fluid pressure and flow speed, particularly in the context of fluid dynamics. Participants explore concepts related to pressure in both liquids and gases, addressing misconceptions and clarifying definitions while examining specific scenarios involving pipelines.
  • Mak questions the inverse relationship between fluid pressure and flow speed, suggesting that if slowing down a fluid increases pressure, then a fluid at rest should have infinite pressure.
  • One participant clarifies that while higher pressure corresponds to lower velocity in equilibrium, the relationship is not a constant ratio, referencing Bernoulli's principle.
  • Another participant asserts that volume is unrelated to pressure in this context and emphasizes that gases are fluids, countering a previous claim that gases are not fluids.
  • Mak poses a scenario comparing two pipelines with different cross-sectional areas, asking which pipeline would have higher pressure under specified conditions.
  • A later reply indicates that the pipeline with the smaller cross-sectional area will have higher velocity and thus higher pressure, regardless of whether the fluid is a gas or a liquid.
Participants express differing views on the relationship between pressure and flow speed, with some clarifying misconceptions while others raise further questions. The discussion remains unresolved regarding the implications of pressure in static versus flowing fluids.
Participants highlight assumptions about fluid properties, such as incompressibility and temperature consistency, which may affect the discussion's conclusions. The distinction between gases and liquids as fluids is also a point of contention.
This discussion may be useful for students or enthusiasts of fluid dynamics, particularly those seeking to understand the nuances of pressure and flow relationships in different types of fluids.
TheMak
Hey Everybody! It's my first time posting here, so please forgive any
errors that might creep into this post.
I'm a guy who loves physics. In fact, it has been my favorite subject ever
since I can remember, and in physics, the field that attracts me the most
is kinematics. Well, the question I have is about fluid flow, specifically,
the pressure of a fluid. I've never been good at fluid dynamics and
kinematics so if this sounds like an idiotic question, I'm sorry in
advance.
Everywhere I read, it is said that fluid pressure is inversely related to
the speed of the flow. Meaning that if a fluid is flowing through a pipe at
a flow rate of say, 10Kg/second, it will be exerting more pressure than it
would if it were flowing at a rate of 5Kg/second. Basically, it means that
in order to increase the pressure of a fluid, you have to slow it down and
expand its volume. This seems so counter-intuitive! By extension, if a
fluid is at rest, mass flow rate is 0Kg/sec and it's volume is made
infinite, it must have infinite pressure?! This means that the air in the
room I'm sitting should be at an infinite pressure and crush me
immediately! But that is not the case.
Basically, what I'm saying is that if I can increase the pressure by
decreasing the speed of fluid flow, then is not a fluid at rest also at
infinite pressure?
So what is pressure? I always thought that pressure was generated by
confining a large amount of fluid in a small volume. The more the fluid and
the smaller the volume, the higher the pressure. Am I right or wrong? And
what's with the fluid pressure while it's flowing?
I look forward to your answers as I have registered with physics forums
specifically for asking this question.
Thanks,
Mak.
Higher pressure corresponds to a lower velocity (in equilibrium), but this does not imply a constant pressure/velocity ratio.
Instead, [itex]\frac{v^2}{2}+\frac{p}{\rho}[/itex] is constant, where v is the velocity, p is pressure and rho is the density of the fluid. With zero velocity, you get a maximum, but finite pressure.
Volume is completely unrelated here - and in most cases, it is a good approximation to assume that liquids[STRIKE]fluids[/STRIKE] cannot be compressed at all. Air is a gas, not a liquid[STRIKE]fluid[/STRIKE].
Assuming a constant temperature: Right.
Edit: Sorry, was confused.
mfb said:
Volume is completely unrelated here - and in most cases, it is a good approximation to assume that fluids cannot be compressed at all. Air is a gas, not a fluid.
This is completely wrong. All gases are fluids by definition. Conversely,
all liquids are fluids, but not all fluids are liquid.
Thanks for the replies guys! but I still have doubts regarding this. Which direction is this pressure being exerted? I'll simplify my question,
If I were to give you two pipelines carrying the same fluid, with the following constraints:
1. Both pipelines carry the same amount of fluid in Kg/s
2. Fluid in both pipelines is at the same temperature
3. Same fluid in both pipelines, so no diff. in viscosity, density or other flow characteristics and physical properties.
4. Both pipelines are parallel to the ground with no slopes of any kind
5. Flow is streamlined in both pipelines, no turbulence of any kind
AND
6. One pipeline has a cross sectional are of 100 cm^2 and another has a cross sectional area of 1000 cm^2
In which pipeline is the fluid at a higher pressure?
OR
Which pipeline has the higher pressure?
Can you answer the question once considering the fluid to be a liquid (more or less incompressible) and once considering it to be a gas?
Looking forward to your replies!
Hi TheMak,
Both the fluids are flowing at the same mass flow rate. As fluid properties are also the same, the volumetric flow rate may also be considered to be equal.
As the pipes have different cross sectional areas, the fluid velocities would be different. Pipe A with the smaller cross sectional area of 100 cm^2, will have a higher velocity compared to pipe B with the larger x-sectional area of 1000 cm^2.
Pipe A will have a higher pressure compared to pipe B.
The results would not change if considering a gas or a liquid.
  • · Replies 35 ·
  • · Replies 48 ·
  • · Replies 25 ·
  • · Replies 48 ·
  • · Replies 17 ·
