Projectile Motion(difficulty level-7)
  • Thread starter Thread starter XtremeChic4
    Projectile
The discussion focuses on solving a projectile motion problem involving a football kicked at a 50-degree angle, which travels 20 meters before hitting the ground. The initial speed of the ball is calculated to be 14.1 m/s, with a flight duration of 2.2 seconds and a maximum height of 5.94 meters. Key formulas used include the horizontal and vertical components of initial velocity, time of flight, and maximum height calculations based on gravitational acceleration.
  • Understanding of projectile motion principles
  • Familiarity with trigonometric functions (sine and cosine)
  • Knowledge of kinematic equations for motion
  • Basic grasp of gravitational acceleration (9.8 m/s²)
  • Study the derivation of projectile motion equations
  • Learn about the effects of air resistance on projectile motion
  • Explore advanced projectile motion problems involving varying angles
  • Investigate real-world applications of projectile motion in sports
Students studying physics, educators teaching mechanics, and anyone interested in understanding the dynamics of projectile motion in sports contexts.
XtremeChic4
A football is kicked at an angle of 50 degrees and travels a distance of 20 m before hitting the ground.
What is the initial speed of the ball? (14.1 m/s)
How long is it in flight? (2.2 sec)
How high does it rise? (5.94 m)
I have the answers but I don't know where to go with the information that is given. If anyone could help explain this problem, it would be greatly appreciated! Thanks!
XtremeChic4:
don't double post... I answered your question in the K12 forum already...
people:
if you guys want to reply to his question... goto K12 forum..
Sure, I'd be happy to help explain this problem to you! Projectile motion is a type of motion where an object, in this case a football, is launched or thrown at an angle and travels through the air under the influence of gravity. This type of motion can be broken down into two components: horizontal and vertical motion.
In this scenario, the football is kicked at an angle of 50 degrees. This angle is measured from the horizontal ground. The initial speed, or velocity, of the ball can be calculated using the components of the initial velocity in the horizontal and vertical directions. The horizontal component of the initial velocity can be found by using the formula v₀x = v₀cosθ, where v₀ is the initial velocity and θ is the angle of launch. In this case, v₀x = v₀cos50 = 14.1 m/s.
The vertical component of the initial velocity can be found by using the formula v₀y = v₀sinθ, where v₀ is the initial velocity and θ is the angle of launch. In this case, v₀y = v₀sin50 = 11.4 m/s.
Now that we have the initial velocity components, we can use them to solve for the other parts of the problem. The time of flight, or how long the ball is in the air, can be found using the formula t = 2v₀y/g, where g is the acceleration due to gravity (9.8 m/s²). In this case, t = 2(11.4)/9.8 = 2.2 seconds.
To find the maximum height that the ball reaches, we can use the formula h = v₀y²/2g. This formula represents the vertical displacement of the ball at its highest point. In this case, h = (11.4)²/2(9.8) = 5.94 meters.
So, to recap, we were able to find the initial speed of the ball using the given angle of launch and distance traveled. We also found the time of flight and maximum height reached by using the initial velocity components and the acceleration due to gravity. I hope this explanation helps you understand and solve similar projectile motion problems in the future!
  • · Replies 18 ·
