Which Specific Heat Ratios Should I Use for Rocket Propellant Gases?
The discussion revolves around determining the appropriate specific heat ratios for gases produced in a solid-fueled rocket combustion reaction. Participants explore how to calculate an overall specific heat ratio based on the gases involved, including Oxygen, Carbon Dioxide, and Water Vapor, and their respective contributions to the combustion process.
  • One participant seeks guidance on which specific heat ratios to use for gases produced in a rocket engine, specifically asking about Oxygen, Carbon Dioxide, and Water Vapor.
  • Another participant suggests using a formula for the average specific heat ratio based on molar fractions of the chemical products.
  • A participant questions whether to use molar ratios instead of weight ratios for calculating the average specific heat ratios, noting the units involved.
  • Further clarification is provided that both molar and mass weighted averages should yield similar results for specific heat ratios.
  • A participant expresses relief at being able to use mass ratios for specific heat calculations, indicating they had already performed related calculations.
Participants generally agree on the need to calculate an average specific heat ratio, but there is some uncertainty regarding whether to use molar or mass ratios. The discussion remains unresolved on the best approach to combine the specific heat ratios of the gases involved.
Participants reference specific heat ratios in terms of both molar and mass fractions, indicating potential limitations in definitions and assumptions about the gases' energetic states.
mrjeffy321
Hello,
I know that the Specific Heat Ratio when referring to the gass(es) coming out the back of a rocket engine is the ratio of the specific heats at a constant pressure/volume and then what I am trying to do is use that to help me solve for what the theoretical force I can expect from the rocket using a rather long equation.
Here is my question,
I don't know which specific heat ratios to use and for which gasses?
I have found many tables that list common gasses specific heat rations, the most meaningful being Oxygen gas, Carbon Dioxide, "Air", and Water Vapor/Steam, all of which are involved with a combustion reaction that is taking place inside my solid fueled rocket (propelent is Potassium Chlorate + Sucrose),
the reaction is a combination os two reactions actually,
first the chlorate decomposes: 2KClO3 --> KCl + 3O2
second, the oxygen made during the first reaction is used to combust the sucrose: 12O2 + C12H22O11 + 11H2O
which is then combined to this reaction:
8KClO3 + C12H22O11 --> 12CO2(g) + 11H20(g)
so I know the ratio of gasses to each other, their molar wieghts, each individuals specific heat ratios, but how do I combine them all to find the overall specific heat ratio of the whole reaction?
is it just the average so to speak of carbon dioxide and water vapor? would I just find out the ratio of carbon dioxide's weight to water vapor's weight and then use that to determine the average specific heat ratio?
If I were you I'd do:
[tex]\gamma_{average}=\frac{\sum X_i C_{pi}}{\sum X_i C{vi}}[/tex]
where Xi is the molar fraction of the i-th chemical product.
So I was correct in thinking that I needed to take the average of the gasses in the product,
but it is the molar heat ratio, and not the weight ratio?
are you sure? even though my specific heats are given in kJ/kg*degree kelvin, but then the units would cancel I suppose when you divided them.
so for the above reaction,
I would take the average ( i use italics because it really isn't a true average), specific heat ratios of carbon dioxide and water vapor, using the ratios 12/23 for carbon dioxide and 11/23 for oxygen, and we just disreguard the oxygen in the middle that is coming off the chlorate and going right back into another reaction,
rather than doing the ratio of their weights
Sorry, I forgot to say that Cp_i and Cv_i are the molar heat capacities. I think you will obtain the same number (or at least a very close number to that) if you calculate it by means of the mass fraction and the mass heat capacities. The fact is such coefficients are calculated assuming an equal energetic state of both the complete mixture and the sum of the components:
[tex]U=N_{total}C_{Vaverage}T)_{average of the mixture}=\sum U_i[/tex]
If you start from that point, using a mass weighted average or molar weighted average you will obtain an equivalent number for Cv (molar or mass based).
OK, thanks, so I will go good to continue with my mass ratioed specific heat ratios, that makes my life slightly easier since I had already worked out the math and I won't have to look for a new table with the substances' molar spcific heat ratios (even though it should be the same in theory, since it is the ratio I want, not the actual specific heats).
  • · Replies 26 ·
9K
17K
