Terminal velocity of a rocket using dimensional analysis
The discussion revolves around deriving a formula for the terminal velocity of a rocket using dimensional analysis. Participants explore the relationships between various physical parameters such as air density, gravity, rocket area, mass, and drag coefficient. The conversation includes attempts to clarify the dimensional analysis process and the implications of mass on terminal velocity.
  • One participant expresses confusion regarding dimensional analysis and attempts to derive a formula for terminal velocity, noting that their initial approach seems incorrect.
  • Another participant suggests using the gravitational force (mg) as a single variable to simplify the analysis.
  • A participant provides a derived formula for terminal velocity and discusses the implications of mass in the context of dimensional analysis.
  • There is a mention of the constant of proportionality in the actual formula for terminal velocity, with a participant questioning the origin of the factor of 0.5.
  • Further elaboration indicates that the constant is determined experimentally and cannot be derived from dimensional analysis alone.
  • One participant introduces a more complex approach involving different dimensions for x, y, and z distances, leading to a similar terminal velocity expression.
Participants do not reach a consensus on the dimensional analysis process and the implications of mass on terminal velocity. Multiple approaches and interpretations are presented, indicating ongoing uncertainty and exploration of the topic.
Some assumptions regarding the relationships between variables are not fully resolved, and the discussion includes various interpretations of dimensional analysis that may depend on specific definitions or contexts.
Enthu
I started taking MIT's online physics course a couple of days ago, and since I have no physics background at all, I'm getting a bit confused with dimensional analysis.
I'm trying to find a formula for the terminal velocity of a rocket, using air density ρ, gravity g, area of rocket affected by air A, mass m and the drag coefficient Cd. I have reached the following equation of dimensional analysis:
LT-1 = [M]V[itex]\cdot[/itex][LT-2]W[itex]\cdot[/itex][ML-3]X[itex]\cdot[/itex][L2]Y
I'm pretty sure that is completely wrong. I tried solving for the coefficients and ended up with V = 1 X = 1/2 W = 1 Y = 1/2, and I'm certain that is wrong as well.
Can somebody help me with this? I just can't seem to get a correct formula.
Also, as far as I understood it, from the equation above it is implied that mass should have no effect, but the actual formula for the terminal velocity of a rocket does have mass in it.
--this isn't a homework/coursework question, I'm doing this out of my own curiosity--
Well, you have 4 variables and just 3 equations. Possible fix: Use the gravitational force of the rocket, m*g, as single variable.
Anyway:
Solving for M gives V=-X (note the sign).
Solving for T gives W=1/2
The equation for L is now 1=W-3X+2Y, which can be simplified to 1/2 = -3X+2Y.
If m and g can appear as m*g only, this implies V=W and therefore V=1/2, X=-1/2. This allows to determine Y=-1/2.
As final formula:
[tex]v \propto \sqrt{\frac{mg}{\rho A}}[/tex]
Ah, thanks. I get it now. Any idea how the actual formula got to [itex]v = \sqrt{\frac{mg}{\frac{1}{2}ρC_dA}}[/itex] (i.e. where's that 0.5 from)?
That is the constant of proportionality.
If, for example,
[tex]v \propto \sqrt{\frac{mg}{C_d\rho A}}[/tex]
then to introduce an equality sign, we have to introduce a constant,
[tex]v = k \sqrt{\frac{mg}{C_d\rho A}}[/tex]
Usually, this constant is evaluated by experiments. In this particular case k came out to be [itex]\sqrt{2}[/itex] You cannot get it by dimensional analysis because the number has no dimension by itself.
If, for example,
Oh, that's something I must have missed going through my papers. Thanks.
I know this is not a "standard" analysis, but you can say that the x, y, and z distances have different dimensions. In other words, you have 5 fundamental variables m, t, Lx, Ly, and Lz. Then, assuming the z direction is the direction of motion (up):
[tex]v\propto L_z/t[/tex]
[tex]\rho\propto\frac{m}{L_x L_y L_z}[/tex]
[tex]g\propto L_z/t^2[/tex]
[tex]A\propto L_x L_y[/tex]
and you get
[tex]\frac{L_z}{t}\propto\left(m\right)^a\left(\frac{L_z}{t^2}\right)^b\left(\frac{m}{L_xL_yL_z}\right)^c\left(L_xL_y\right)^d[/tex]
You can solve to get a=b=1/2 and c=d=-1/2, and get [tex]v\propto\sqrt{\frac{m g}{A \rho}}[/tex] same as above. Check out http://en.wikipedia.org/wiki/Dimensional_analysis#Huntley.27s_extension:_directed_dimensions for an explanation of this refinement of dimensional analysis
(Note - the area is Lx Ly because the plane of the area is perpendicular to the direction of motion)
  • · Replies 165 ·
9K
  • · Replies 18 ·
  • · Replies 41 ·
  • · Replies 17 ·
  • · Replies 26 ·
