New Reply
Surface Area of a Multivariable function
Share Thread Thread Tools
Jun1-12, 01:30 PM   #1
I don't know how to calculate the surface area after setting everything up. I have tried both MAPLE 15 program and wolfram alpha, but I can't find the answer.
I have the function:
f(x,y)= x*(y^2)*e^-((x^2+y^2)/4)
The form I found for surface are was the square root of (sum of squares of partials with respect to x and y).
The work I have so far
∫∫√(e^(-(x^2+y^2)/4))*(y^4-(3x^2*y^4)+(4y^2*x^2)+((x^4*y^4)/4)+((x^2*y^6)/4)+1 dx dy
I have to integrate from -3 to 3 for both x and y.
I have tried putting it into MAPLE 15, but it won't solve the function for a value.
What should I do? Is there any way to simplify this algebraically so that it is easier to solve? Is it even possible to solve it by hand?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Jun1-12, 02:07 PM   #2
try spherical/cylindrical coordinates
Jun1-12, 02:11 PM   #3
What would the limits of integration be though? It is not shaped anything like a cylinder or sphere.
Jun1-12, 03:16 PM   #4
Recognitions:
Homework Helper Homework Help
Quote by mariya259 View Post
I doubt that there is a closed-form formula for the area, so try a numerical approach. If you call dA your integrand, the following works for me in Maple 11:
Jx:=evalf(Int(dA,y=-3..3));
Area:=evalf(Int(Jx,x=-3..3));
Area := 44.43229369
RGV
Jun1-12, 05:48 PM   #5
Isn't it an odd function in the appropriate sense? You do not have to do the integration, you can realize the value "by inspection".
Ray Vickson has pointed out below that I made a (large) oversight.
Jun1-12, 10:57 PM   #6
Recognitions:
Quote by algebrat View Post
I think you have misunderstood the problem. For a graph of the form [itex] z = f(x,y)[/itex] the surface area S of the graph over a region [itex] A \subset R^2 [/itex] in (x,y)-space is
[tex] S = \int\int_{A} \sqrt{1 + f_x^2 + f_y^2} \: dx \, dy,[/tex]
where [itex] f_x = \partial f/\partial x,\; f_y = \partial f/\partial y.[/itex] For [tex]f = x y^2 \exp{\left(-\frac{x^2 + y^2}{4}\right)} [/tex] we have
[tex] f_x = \frac{1}{2}y^2 (x^2-2) \exp{\left(-\frac{x^2 + y^2}{4}\right)}\\
f_y = \frac{1}{2}x y (y^2-4) \exp{\left(-\frac{x^2 + y^2}{4}\right)}.[/tex]
Do you really think the double integral S can be evaluated by inspection?
RGV
Jun2-12, 01:49 AM   #7
Yes, that was my mistake, thank you Ray!
Jun2-12, 03:42 AM   #8
Try parametrising it in some other way.
Jun2-12, 03:47 AM   #9
So dimension10, are you thinking some thing like polar coords., r goes from 0 to 3 cos theta?
Oh yeah sorry, I'm not reading very carefully.
Jun2-12, 04:35 AM   #10
[Post cleared]
Jun2-12, 06:30 AM   #11
never mind, deleted
Jun2-12, 04:56 PM   #12
how would i parametrize this function?
Jun2-12, 11:37 PM   #13
I'm not sure but I would suggest a way through which you can use some algebraic/trigonometric identities OR reverse chain rule/reverse product rule.
Jun3-12, 02:16 AM   #14
Recognitions:
No matter what you do the function will not have a closed-form double integral. The only reason to bother parametrizing is to make it easier to fit the shape of the region [itex] A \subset R^2[/itex] over which you want to take the surface area. So, if A is rectangular with sides parallel to the x and y axes, just use the original parametrization. If A is a circular disc, you could switch to polar coordinates. If A is an elliptical disc, re-scale x and y to make it a circle, then switch to polar coordinates. In every case you will be forced to get a numerical answer.
RGV
Jun3-12, 02:26 PM   #15
I think I would have to keep the original though, because here is how the region looks like
http://www.wolframalpha.com/input/?i...2F4%29%2B1+%29
Jun3-12, 03:07 PM   #16
with your region, in wolfram alpha, I think you need to put the 1 outside the parenthesis in the square root
Jun3-12, 03:18 PM   #17
Recognitions:
I think you have the wrong integrand: your integrand should be of the form
[tex] \sqrt{1 + e^{-(x^2+y^2)/2} \cdot \text{some function of x and y}},[/tex] but that is not what you have.
RGV
New Reply
Tags
integration, surface area
Thread Tools
Similar Threads for: Surface Area of a Multivariable function
Thread Forum Replies
Volume of a cube as a function of surface area Precalculus Mathematics Homework 1
Multivariable Calc Problem (Surface Area/Integral) Calculus & Beyond Homework 2
Polar Regions: Area, Arc Length, and Surface Area Calculus & Beyond Homework 2
Center of Mass and Surface Area (multivariable) Calculus & Beyond Homework 3
Surface area of a function Calculus & Beyond Homework 3
