Why Doesn't the Earth Move When Objects Fall?
  • Thread starter Thread starter Bashyboy
    Gravity
The discussion revolves around the question of why the Earth does not appear to move when an object falls under the influence of gravity. Participants explore the implications of Newton's third law and the relationship between force, mass, and acceleration in this context.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants examine the calculations related to the forces acting on both the object and the Earth, questioning why the gravitational acceleration experienced by the Earth changes with the mass of the falling object. Some express confusion about the implications of constant mass and the resulting accelerations.
There is an ongoing exploration of the concepts involved, with some participants suggesting that the Earth's acceleration is indeed very small due to its large mass. The discussion reflects a mix of interpretations and attempts to clarify the underlying principles without reaching a definitive conclusion.
Participants are grappling with the assumptions regarding mass and acceleration, particularly in the context of Newton's laws. There is an acknowledgment of the complexity of the situation, especially regarding the relative scales of mass and acceleration involved.
Bashyboy
The question I am looking at is: "When an object falls freely under the influence of gravity there is a net force mg exerted on it by the earth. Yet by Newton's third law the object exerts an equal opposite force on the earth. Why doesn't the Earth move?"
My actual problem isn't with the question, but with the solution, which I read after I solved it. To solve the problem, the gave a simple calculation to find the answer. The imagined a 1 kg object, and they approximated Earth's mass to be of the order of 10^25 kg.
They stated that [itex]F_{_{Earth}} = F_{_{Object}}\rightarrow(10^{25} kg)a = 1 kg\cdot9.8m/s^2[/itex] And solving for a would give [itex]9.8\cdot10^{-25} m/s^2[/itex]
So, the gravitational acceleration the object provides would be that minute number. But say the object had a mass of 100 kg. Re-doing the calculations would yield [itex]9.8\cdot10^{-23}m/s^2[/itex] Why does this gravitational acceleration change? Shouldn't Earth's gravitational acceleration change then? I now my thinking is erroneous somehow, but I can't seem to figure out why. Does it maybe have to do with Earth's mass be constant? I'm not entirely sure.
OK, that's the acceleration of the Earth due to the object's mass.
The force on it (the Earth) increased by a factor of 100, yet its mass remained the same.
I assume you mean: Shouldn't the acceleration of the object change? No, since both force and mass increased by the same factor.
There is a lot easier way to do the problem without equations, but just with common knowledge.
Newton's third law states that every object exerts an equal and opposite force on another.
The force that the ball exerts on the Earth is the same as the force that the Earth exerts on the ball, so why does the Earth not move?
The reason involves one simple formula: F = ma. This formula can be manipulated to read a = F/m, where a is the acceleration, F is the force, and m is the mass.
The ball's acceleration is (force) / (small mass) = HIGH ACCELERATION
The Earth's acceleration is (force) / (huge mass [5.9742 × 10^24 kg]) = SMALL ACCELERATION
Thus, the Earth DOES move up to meet the ball, but at such a small distance that we cannot see it.
Hope this helps!
Thanks,
Manan
The Earth does accelerate towards the object, but with an extremely small acceleration.
