| New Reply |
Derivative of Dirac Delta function |
Share Thread | Thread Tools |
| Jun2-12, 09:22 AM | #1 |
Hello I'm trying to figure out how to evaluate(in the distribution sense)
[itex]\delta'(g(x))[/itex]. Where [itex]\delta(x)[/itex] is the dirac delta function. Please notice that what I want to evaluate is not [itex] \frac{d}{dx}(\delta(g(x)))[/itex] but the derivative of the delta function calculated in g(x). If anyone could post a proof, an idea to find the proof or a link it would be greatly appreciated! |
| Jun2-12, 12:19 PM | #2 |
[itex] \delta' [/itex] is a linear operator on functions. Are you referring to its value when you pair it with g(x), as in
$$ \langle \delta',\, g\rangle = \int_{\mathbb{R}} \delta'(x)g(x)\, dx \, ?$$ I'll assume you are. In that case, you use the integral notation above and then symbolically do integration by parts. Don't worry if it is not a well-defined operation because the answer you get is literally the definition of what you want. Look here under distributional derivatives for more info: http://en.wikipedia.org/wiki/Dirac_delta_function |
| Jun2-12, 01:16 PM | #3 |
No I'm sorry if I wasn't clear. I understand the value of
[itex]\int \delta'(x)g(x)dx[/itex] I'm asking the value of [itex]\int \delta'(g(x))\phi(x)dx[/itex] Where [itex]\phi(x)[/itex] is the test function. Here it is not immediately obvious to me how to integrate by parts. I thought about this(but I am unsure of whether it is correct): Assume that g(x) is an invertible function with as many derivatives as necessary(to keep things simple for now), so we substitute [itex]y = g(x)[/itex] and get [itex]\int \delta'(y)\frac{\phi(g^{-1}(y))}{g'(g^{-1}(y))} dy[/itex] Now I could integrate by parts and get [itex]-\int \delta(y)\frac{d}{dy}(\frac{\phi(g^{-1}(y))}{g'(g^{-1}(y))}) dy[/itex] Do you think my reasoning is correct up to here? |
| Jun3-12, 02:13 PM | #4 |
The dirac delta is just a normal distribution who's standard deviation approaches 0. Take the derivative of the normal dist. then take the limit as stdev =>0. I'm not sure if that's a valid way to do the problem, but its what I would try.
| Jun3-12, 05:34 PM | #5 |
Ok thanks, I'll try that
| Jun3-12, 05:35 PM | #6 |
Your calculation looks right to me, and what Aero said makes sense too. As far as proof goes, I can't remember exactly how general the rules are for changing variables like that. A book like Friedlander would probably have it...
Check out the very last post here for a similar problem: http://www.physicsforums.com/showthr...=201774&page=2 There is no proof, but there is a citation. If g is not injective, then in the end, when you evaluate against a test function, you should get a sum of terms, one for each zero of g. If g' and g are simultaneously 0 at any point, then I don't think the distribution is well-defined. |
| New Reply |
| Thread Tools | |
Similar Threads for: Derivative of Dirac Delta function
| prove that derivative of the theta function is the dirac delta function | Advanced Physics Homework | 3 | ||
| Shankar CH1 Derivative of Dirac delta | Quantum Physics | 2 | ||
| derivative of dirac delta function | Calculus & Beyond Homework | 4 | ||
| Derivative of the Dirac Delta | Advanced Physics Homework | 2 | ||
| Derivative of an integral containing a Dirac delta | Calculus | 4 | ||
