| New Reply |
Can anyone tell me the relationship between work done and potential difference?? |
Share Thread | Thread Tools |
| Jun2-12, 10:57 PM | #1 |
CAN ANYONE TELL ME THE RELATIONSHIP BETWEEN WORK DONE AND POTENTIAL DIFFERENCE??
If more work is being done across a component(for ex due to increased resistance), does the pd across it increase or decrease? I think it should increase, because pd is the work done per unit charge, so if the work done increases, so would the pd. AM I right? |
| Jun2-12, 11:25 PM | #2 |
Yes, it would. There may be complications in terms of defining a potential, whether the work done is conservative, etc., but in general yes. Remember, however, that this increase comes from whatever "thing" (in your case, some kind of resistance) that increases the work required to be done.
| Jun3-12, 01:45 AM | #3 |
Well, one must be careful. Usually when one is talking about the work done across a potential difference, one is talking about the work done by the force responsible for that potential difference. The work then shows up as a change in the kinetic energy of the system crossing that potential difference, as per the "work-energy theorem." So if that is the context of the question, note that including resistance does not change the work done by the force associated with the potential difference (that can never be changed, it is given by the charge times the potential difference), but it means that there is also a resistive force doing additional work (which would actually be negative work and would subtract from the kinetic energy). So the answer to the question depends on whether one is talking about all the work being done by all the forces (in which case the work done could be less if there is resistance-- as it would likely be a positive work done by the potential and a negative work done by the resistive force), or if it is just the work done by the force associated with the potential difference (which is independent of any resistance that might be present).
| Jun3-12, 02:31 AM | #4 |
We can say that for example a generator makes a positive work and all components that consume "electricity" makes negative work?
| Jun3-12, 04:59 AM | #5 |
Similarly for resistance, depending on whether it's against or along the original potential. For a resistance (say friction) that's symmetric with respect to the original potential, it could either increase or decrease the "total" potential depending on how you're trying to move the test object. In that case, the potential is probably ambiguous, if given only position information. |
| Jun3-12, 09:04 AM | #6 |
It depends on the frame of reference, but in almost all situations you would normally see, friction does negative work-- regardless of whether the work done by the potential is positive or negative. Also, no "potential' can be associated with friction, so it's best to keep the "potential" concept and the "friction" concept quite separate in your head.
| Jun3-12, 10:20 PM | #7 |
I am just an A level student, so have not come across work energy theorem, or friction as resistance...let me show you a question where a application of my question(in MY level) is shown.
http://www.xtremepapers.com/papers/C..._w11_qp_12.pdf question 35. If i was right(in this post), then my answer would have been C, but apparently the right answer is A, and I dont know why. |
| Jun4-12, 01:03 AM | #8 |
the work done can decrease, even if the potential difference increases. total resistance: R+2 (series resistances) current = 12 / (R+2) (ohms' law) Potential difference across resistor = 12 R/(R+2) (ohms' law again) work done = 144 R /(R+2)^2 (P = IV) This function has a maximum. |
| Jun4-12, 01:23 AM | #9 |
That's correct, and if you want a more physically intuitive version, the point is that when the load resistance is much smaller than the internal resistance, the current is not affected much by the load resistance, so the power dissipated in the load resistor will be proportional to the load resistance R. But as the load resistance exceeds the internal resistance, now the internal resistance is what is negligible, and you just have a fixed voltage across the load resistance R, which by P=V^2/R means the power will drop like 1/R.
| Jun5-12, 01:28 AM | #10 |
| New Reply |
| Tags |
| component, energy, potential difference, work done |
| Thread Tools | |
Similar Threads for: Can anyone tell me the relationship between work done and potential difference??
| How Electric potential and potential difference work in batteries | Classical Physics | 3 | ||
| relationship between the electrical current and the potential difference question | Introductory Physics Homework | 2 | ||
| Potential difference, electric potential energy and work | Introductory Physics Homework | 1 | ||
| relationship between work and potential energy | Introductory Physics Homework | 11 | ||
| Electric work and potential difference | Introductory Physics Homework | 7 | ||
