New Reply
Calculating G-Force
Share Thread Thread Tools
Jun3-12, 02:38 PM   #1
Calculating G-Force
How do you calculate G-Force? I know that one g is the force gravity exerts on a particular mass (I think). But how exactly do you figure it out, particularly with objects spinning in a circle, like a merry-go-round?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Jun3-12, 02:39 PM   #2
V^2/R
Velocity in m/s with that number squared divided by the radius in meters.
Jun3-12, 02:43 PM   #3
Quote by Ferraridude View Post
V^2/R
So, G-Force is the same as centripetal acceleration?
Jun3-12, 09:21 PM   #4
Calculating G-Force
Quote by SignSeeker7 View Post
"G force" is just the ratio of a given force to the force due to gravity on the same object. Think of it as a unit of measure, it's not a special kind of force. Typically, "G forces" are referring to pseudo forces experienced in an accelerating reference frame.
Now, if you wanted to know the gravitational attraction between two objects, then you'd use Newton's law of gravitation.
Jun3-12, 10:29 PM   #5
Yes, if you are going in a circle, or even changing direction. You can also get g force from linear acceleration. If you were in a rocket that could accelerate at 4 g's straight up, or 39.2 m/sec^2 you would be subject to 5 g's. Four from the rocket and one from the Earth.
Jun4-12, 07:47 PM   #6
If you were going around a merry go round with a radius of 15 meters at a velocity of 8 m/s, this is how you would calculate the G-forces.
8^2=64
64/15=approximately 2.67.
So now, you have your m/s^2 for the acceleration.
2.67/9.8 m/s^2 (9.8 m/s^2 is the acceleration of the Earth's gravity)=.2724
So, we can now see that the centripetal force on a merry go round rider with that velocity around a circle with that radius, we are feeling .2724 G's of acceleration, or 27.24% of Earth's gravitational pull.
New Reply
Tags
calculating, circular, g-force
Thread Tools
Similar Threads for: Calculating G-Force
Thread Forum Replies
Environmental force vs. Drag force acting on an object: Calculating motion parameters Introductory Physics Homework 0
Calculating Force Introductory Physics Homework 1
Pressure, force, and Area: Calculating the net Force Applied on A dam by Water Introductory Physics Homework 1
calculating normal force and net force of 20 kg mass going down inclined plane at... Introductory Physics Homework 11
Calculating G Force General Physics 1
