New Reply
Is the signature of this matrix zero?
Share Thread Thread Tools
Jun4-12, 10:23 PM   #1
Recognitions:
Given are two square matrices of the same dimension, M and N.
M is symmetric. N is non singular.
From M and N form the symmetric matrix,
M N
N* 0
Where N* is the transpose of N.
Is the signature of this matrix necessarily zero? Counterexample?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Jun5-12, 08:00 AM   #2
Math 2012
Recognitions:
My "engineer's intuition" says it is true, if you think about finding the extrema of x*Mx subject to the constraints Nx = 0, using Lagrange multipliers. The situations where this runs into trouble are when the constraints are not all independent, but that is excluded because N is non-singular.
Basically, each eigenvalue of M is turned into a pair of eigenvalues of the augmented matrix, one positive and one negative.
But my brain isn't working well enough to turn that idea into a proof right now - sorry!
Jun5-12, 09:50 AM   #3
I think a topological argument works here.
If you continuously deform such a matrix (within the constraints you mentioned), then the signature cannot change without an eigenvalue crossing 0. But that cannot happen without the determinant being zero. But such a matrix cannot have zero determinant because its rows are independent. In other words, the signature cannot change under a continuous deformation that maintains the given constraints on M and N.
Every symmetric matrix can be continuously deformed to 0 (by scaling it down to 0). And GL(n) only has two connected components, so each non-singular matrix can be deformed to I or I' (which is I with one entry flipped to -1). So it suffices to check M=0, N=I, and M=0,N=I'.
Jun5-12, 11:59 AM   #4
Recognitions:
Homework Helper Homework Help
Pick for instance M=(0) and N=(1).
Determinant=-1
Trace=0
Eigenvalues are +1 and -1.
Jun6-12, 05:42 AM   #5
Recognitions:
Quote by Vargo View Post
Very cool argument. It took me a while to get it.
I am going to try to generalize this to the matrix
M T 0
T* M N
0 N 0
where the conclusion now - I think - would be that the signature is this matrix is the signature of M. Can I just shrink T to zero?
Jun6-12, 06:12 AM   #6
Recognitions:
Quote by AlephZero View Post
This is the approach I have tried - more or less. I get a system of quadratic equations.
Jun6-12, 09:08 AM   #7
Recognitions:
Quote by lavinia View Post
M T 0
T* M N
0 N 0
If T is shrunk towards zero the the matrix becomes singular only if M is singular so your proof goes through.
Jun6-12, 09:28 AM   #8
M T 0
T* M N
0 N 0
Lets see... The determinant of this matrix will equal [itex] (-1)^n(\det M) (\det N)^2[/itex], where n is the block size. If M is non-singular, the determinant is never zero, so no signature changes could happen by shrinking T down to zero.
If M is singular, the conclusion still sounds plausible, but I'm not sure whether the same proof could be adapted.
Jun9-12, 08:49 AM   #9
Recognitions:
If M is diagonal then T can be shrunk to zero in the plane of non-zero eigen values.
Choose a basis of eigen vectors for the copy of M that is in the upper left corner of the matrix.
New Reply
Thread Tools
Similar Threads for: Is the signature of this matrix zero?
Thread Forum Replies
How do I set up my signature? Forum Feedback & Announcements 9
how to find matrix signature Linear & Abstract Algebra 2
My signature as well as those of others are present when I log in Forum Feedback & Announcements 11
signature General Discussion 6
Using signature Forum Feedback & Announcements 2
