Why Do Electric Field Lines Never Cross?
This discussion focuses on the properties of electric field lines and the calculation of electric field strength from a point charge. Key points include that electric field lines are always perpendicular to the surface of an isolated conductor, never intersect, and indicate the direction of force on a test charge. The electric field strength at a point 30 cm from a charge Q=-3.0x10^(-6)C is calculated using the formula E=k0 x Q/(r^2), resulting in a magnitude of 3.0x10^5 N/C, which is positive when considering strength alone, despite the charge being negative. The direction of the field is away from the charge for positive test charges.
  • Understanding of electric field concepts
  • Familiarity with Coulomb's Law
  • Knowledge of vector magnitudes and directions
  • Basic principles of electrostatics
  • Study the concept of electric field lines and their properties
  • Learn about Coulomb's Law and its applications in calculating electric fields
  • Explore the significance of electric field direction and magnitude
  • Investigate the behavior of electric fields around different charge configurations
Students and educators in physics, particularly those studying electrostatics, as well as anyone seeking to deepen their understanding of electric fields and their implications in physical scenarios.
ness87
(1)Which of the following statements about electric field lines is false?
a) They are perpendicular to the surface of an isolated conductor
b) They never intersect
c) They indicate the path along which a test charge moves
d) More indicate a stronger field
e) They can be either straight or curved
f) They indicate the force on a test charge
I have no idea how to answer this
because they all seem to be true!
(2) The electric field strength at point P which is 30cm to the right of a point charge Q=-3.0x10^(-6)C is:
a) 1.3x10^5 N/C
b) 9.0x10^4 N/C
c) 3.0x10^5 N/C
d) 5.5x10^5 N/C
I know the answer to this one is (c) however, why is it positive?? when I calculate the electric field I use E=k0 x Q/(r^2) and it is a negative answer -3.0x10^5 N/C.
(3) For the previous question, the field at this point, points:
a) towards the charge Q
b) away from the charge Q
c) up
d) down
If you can help me understand the answers and why that would be useful, I can't get my head around electric fields for some reason
Give your justification for each one being true.
a) 1.3x10^5 N/C
b) 9.0x10^4 N/C
c) 3.0x10^5 N/C
d) 5.5x10^5 N/C
They're only asking for the electric field strength which is the magnitude of the field, not the direction.
c) up
d) down
For (3); In what direction would the force be on a positive charge, placed at this point?
  • · Replies 16 ·
