Problem on divergence and curl
  • Context: Graduate
  • Thread starter Thread starter heman
    Curl Divergence
The discussion revolves around the concepts of divergence and curl, including their definitions, significance, and applications in physics, particularly in the context of vector fields and theorems such as the Divergence Theorem and Stokes' Theorem. Participants seek to clarify these concepts and their implications in various physical scenarios.
  • One participant expresses difficulty in understanding divergence and curl, seeking help with their significance rather than just their formulas.
  • Another participant explains that divergence measures the change in density of a field, while curl measures the curvature of a field.
  • A participant provides a detailed mathematical definition of divergence and curl, describing the processes involved in calculating them.
  • There are discussions about the applications of divergence and curl in fields such as electromagnetism, fluid dynamics, and heat transfer.
  • Some participants question how divergence and curl simplify complex equations, particularly in the context of Maxwell's equations.
  • One participant mentions that without divergence and curl notation, Maxwell's equations would become significantly more complex.
  • Another participant attempts to relate the definitions of divergence and curl to physical laws, such as Coulomb's law and conservation of energy.
  • There is a challenge to the explanation of curl being zero in static electric fields, leading to further inquiry about the reasoning behind this claim.
Participants express varying levels of understanding and confusion regarding the significance of divergence and curl. While some provide definitions and applications, others question the clarity of these explanations and seek further elaboration. The discussion reflects multiple competing views and remains unresolved on certain points, particularly regarding the implications of curl being zero in static situations.
Some participants indicate that the definitions and explanations may lack context, suggesting that diagrams and previous discussions could clarify the concepts further. There are also references to specific mathematical steps and physical laws that are not fully resolved in the conversation.
heman
Hi Guys,,
i have just started to study Divergence and curl but this is not at all enetering into my mind...Pls help me out understand this...This also has Divergence and Stokes theorem ..pls help me grasp it...Thx in advance...
The Divergence Theorem and Stokes's Theorem provide the interpretation of the divergence and curl that we have given above.
The integral, over a surface S, measures the flux of v through the surface, which is proportional to the number of arrows of v that cross S.
By the divergence theorem if we take a tiny region V, the integral of div v over this region (which is the average value of div v in it times the volume of V), is the net outflux of v over the surface of V. Thus this outflux, which for V centered on the point r' is a measure of the number of v arrows originating from around the point r' is directly proportional to the average divergence of v around r'.
An exactly analogous interpretation of Stokes's Theorem on a surface S including the point r' provides our interpretation of the curl. The circulation integral of v around a small cycle encircling r can be interpreted as the difference between the path integral of v going around r' on one side and the other. By Stokes' Theorem, this is proportional to the area of the region between the paths times the average value of the component of curl v normal to S in that area. Thus Stokes' Theorem means that the average component of curl v normal to S around r' is directly proportional to the amount of path dependence of v in S produced in the neighborhood of r'.
54 ppls have seen but no one willing to help...
It is somewhat unclear what you're after:
Do you want some "wordy" explanation; is that it?
The essay above is very clear already... if you don't point out what you don't understand more specifily, even we type a millions words here you still won't understand...
Why don't you tell us which part you don't understand so that we can help you...
usually ppls don't reply for 2 reason... unclear question and stupid question... yours is the former
Thx actually i am not getting what does divergence and curl mean...i mean to say not their formulae but their significance ,,what does they want to speak..
The divergence is a measurement of the change in density of something, like a field in a given area.
The curl, is just the measurement of the curvature of a field.
Right?
Checkout mathworld.wolfram.com for both mathematical and a decent, if not complicated, description of what they represent.
I can't make sense out of that. It sounds like you quoted part of a book and without the context (there is a lot that isn't said that there which is probably made clear in diagrams and previous paragraphs and shown equations etc) and as such it gave me a headache reading it. :-p
The divergence of a vector field is simply this - Suppose there is a vector field E. Choose a point r in that field and construct a closed surface, e.g. a sphere, around that point. Take the surface integral of the normal component of E over the closed surface and divide the result by the volume enclosed by that surface. Now let the radius of the spherical surface go to zero. That result is called the "divergence of E."
The curl is kind of like that - Take a point in space and pass a plane through it whose surface normal is parallel to the z-axis. In that plane construct a cirlce whose center is the point of interest. Take the line integral of the vector field around that circle. Let the sense of the line integral be consistent with the right hand rule with the +direction of the z-axis (if you grab the z-axis and your thumb is pointing in the +direction then the direction of the integration around the cirlce will be in the direction your fingers are curling). Now divide the result of that integral by the surface area of the circle. Take the limit and let the radius of the circle go to zero. That gives a number which is called the "z-component of the curl of the vector field E at the point." Do that with two other planes whose surface normals are in the +x and +y direction and you have the components of the curl vector.
Pete
change in density...like density increase n decrease..its rate..
actually again comes basic problem..i know what is formula of curvature but not thorough what they represent..emphasis...i am checking it.thx
thx Pete and Healey but what purpose they solve...in which way are they useful to us...can u explain with the help of example...
example? here you go...
electromagnetic, fluid dynamics, continuity equation, heat transfer...
in what way ...they find their application here i agree..but how do they make the problem simple..i mean to say is there were no divergence and curl ...what could have been there //
if you don't use the div and curl notation, the 4 maxwell equations for EM will become a 20 variable, 20 equations monster
can i ask how ,,i am getting this but i read that in a static situation, the curl of the electric field is zero, and the divergence of the electric field is a multiple of the electric charge density c(x,y):
div(E(x,y)) = c(x,y) and curl(E(x,y)) = 0
how does this evolve...
do you prefer me answering this question verbally or mathematically?
thx...verbally and may be if some maths is necessary
24 equations with 22 unknowns...Yet 22 equations are independent...
Daniel.
for the divergence, it came from the coulomb's law... imagine you have a box. if you see a net electric flux goes in/ come out the box, coulomb's law tells you that there is a net charge in the box.. as the #7 post said, divergence is define as the net flux goes out the box divided by its volume,
[tex]\nabla \cdot \vec{E} = \lim_{\Delta V \rightarrow 0} \frac{\int \vec{E} \cdot d \vec {S}} {\Delta V}[/tex]
applied the coulomb law to the right hand side
[tex]\nabla \cdot \vec{E} = \lim_{\Delta V \rightarrow 0} \frac {q/\epsilon}{\Delta V}= \frac{\rho}{\epsilon}[/tex]
the curl E = 0 came from conservation of energy... we know any line integral of a closed loop is zero for E field otherwise a charge run along the loop will gain energy every lap its finish... again, go back to the definition in post #7
[tex](\nabla \times \vec{E}) \cdot \hat{n} = \lim_{\Delta S \rightarrow 0}\frac{\int \vec{E} \cdot d \vec{l}} {\Delta S}[/tex]
n hat is the normal vector for the area delta S
the integral at the right hand side is zero because the conservation of energy, therefore..
[tex]\nabla \times \vec{E} = 0[/tex]
PS. the mathematical definition for the curl makes sense here because if the E field does not have a rotational tendency, its line integral for a loop will not be zero... you really need to picture it in your mind... hard to explain
The integral at the right hand side is zero because the conservation of energy, therefore..
What?Where did u get that one?
Daniel.
P.S.I noticed you edited your post... :-p
which one?
don't argue with me which definition for div E and curl E is more fundemantal again... this definition can derive any of your difinition in 3D space... and you can really visuallize what's going on physically
yes i edited my post coz i forgot the dot n hat in the curl E
Identify the number of equations and the number of unknowns
[tex]\nabla\cdot \vec{D}=\rho[/tex] (1)
[tex]\nabla\cdot \vec{B}=0[/tex] (2)
[tex]\nabla\times \vec{E}=-\frac{\partial \vec{B}}{\partial t}[/tex] (3)
[tex]\nabla\times \vec{H}=\vec{j}+\frac{\partial \vec{D}}{\partial t}[/tex] (4)
[tex]\vec{j}=\overline{\overline{\sigma}}:\vec{E}[/tex] (5)
[tex]\vec{P}=\epsilon_{0}\overline{\overline{\chi}}^{(el.)}:\vec{E}[/tex] (6)
[tex]\vec{M}=\mu_{0}\overline{\overline{\chi}}^{(mag.)}:\vec{H}[/tex](7)
[tex]\vec{D}=\epsilon_{0}\vec{E}+\vec{P}[/tex] (8)
[tex]\vec{B}=\mu_{0}\vec{H}+\vec{M}[/tex](9)
[tex]\frac{\partial \rho}{\partial t}+\nabla\cdot\vec{j} =0[/tex] (10)
a)Count the equations.
b)Count the unknowns.
c)Count the INDEPENDENT EQUATIONS...
Daniel.
OK, i think i know where is the problem came from, in the maxwell's original equation... [tex]\chi[/tex] is NOT a tensor...
you are right... more than 20/20
vincentchan said:
which one?
Nope,i was asking you how did u deduce that:
[tex](\nabla\times\vec{E})\cdot \vec{n}=0 \Rightarrow \nabla\times\vec{E}=\vec{0}[/tex]
Daniel.
Yes,of course...In ferromagnetic & ferroelectric materials,the [itex]\chi[/itex] cannot be approximated to a second rank tensor...It could be somtehing like
[tex]P_{i}=\chi_{ijk}^{(el.)}E_{j}E_{k}[/tex]
(similar for the magnetic case) or even worse...(Totally nonlinear effects).
Daniel.
P.S.I hope u see that the # of equations has nothing to do with the rank of the polarisability/susceptivity tensor...
since n is arbitrary unit vector, the RHS vanishes iff [itex]\nabla \times \vec{E}=\vec{0}[/itex] I thought it is obvious...
wanna ask you a question... you have 6 variable in [tex]\vec{E} and \vec{B}[/tex], however, E and B is related to the A field and a potential... that's mean you can reduces those 6 variable into 4... that's mean I was right, or, am I right?
What about the ELECTROMAGNETIC POTENTIALS??
What do they have to do with the 24 equations??Keep in mind that the electromagnetic potentials work in the case of the (electromagnetic) vacuum...Not in materials,not in a simple way,that is...
Daniel.
P.S.Unfortunately,here in Belgium i didn't bring that book with me... :cry: So basically,i'll stop here,coz i lack documentation... :cry:
Here is a good example and a simple example. Please see - http://www.geocities.com/physics_world/mech/mass_conservation.htm
As the URL says, its about the conservation of mass. I.e. the total quantity of mass is constant. This means that if there is a region of space in which an amount of mass is flowing out of then the total mass in that region must decrease by the amount that flowed across the surface (that's where flux comes into play). Try to follow the derivation.
vincentchan said:
the RHS vanishes iff I thought it is obvious...
It is not obvious because one does not imply the other. It could be that curl E is non-zero but simply perpendicular to n in which case the dot product is zero.
Pete
pmb,
"It could be that curl E is non-zero but simply perpendicular to n in which case the dot product is zero."
No. n is normal to the infinitesimal surface (defined on the RHS). The orientation of that surface is arbitrary, so if the RHS vanishes, so does the curl.
Pete
It needn't,Pete.it's an equality.Not an implication,simple or double...The surface is arbitrary.If u happen to find a surface whose unit vector's scalar product with the curl is zero,that's an accident.However,u need to make sure that the equality holds for every possible surface...And the only way u can do that is setting the curl to zero.
Daniel.
jdavel said:
pmb,
Yep. You're right. Don't know what I was thinking. Rough day I guess. :biggrin:
Pete
10K
9K
