Is the Carnot efficiency valid for fuel cells?
The discussion centers on the applicability of Carnot efficiency to fuel cells, referencing the article "Thermodynamic comparison of fuel cells to the Carnot cycle" published in the International Journal of Hydrogen Energy. The article argues that while Carnot efficiency is traditionally associated with heat engines, it can also be applied to fuel cells by considering the energy changes in chemical reactions. The authors derive a relationship showing that the maximum efficiency of a Carnot cycle operating on a reaction aligns with that of a fuel cell, contingent on specific thermodynamic conditions.
  • Understanding of Carnot efficiency and its traditional application to heat engines.
  • Familiarity with fuel cell operation and thermodynamic principles.
  • Knowledge of Gibbs free energy and its role in chemical reactions.
  • Basic grasp of enthalpy and entropy in thermodynamic processes.
  • Research the derivation of Carnot efficiency in thermodynamic systems.
  • Study the principles of fuel cell efficiency and performance metrics.
  • Examine the role of Gibbs free energy in chemical thermodynamics.
  • Explore advanced thermodynamic cycles and their applications in energy systems.
Researchers, engineers, and students in the fields of thermodynamics, fuel cell technology, and energy systems who seek to understand the relationship between Carnot efficiency and fuel cell performance.
Metaleer
So, I've read in books and on Wikipedia (see for instance http://en.wikipedia.org/wiki/Carnot...cs)#Applicability_to_fuel_cells_and_batteries) that the Carnot efficiency cannot be applied to a fuel cell because it is not a heat engine that produces work, operating between two heat reservoirs.
However, I have managed to come across the following article, which claims to "dispel the misconception that an ideal fuel cell is potentially more efficient than an ideal heat engine". (Taken from the abstract of
"Thermodynamic comparison of fuel cells to the Carnot cycle", International Journal of Hydrogen Energy, Volume 27, Issue 10, October 2002, Pages 1103-1111
Andrew E. Lutz, Richard S. Larson, Jay O. Keller)
I don't know if copying and pasting from a research journal is allowed here, and I don't think I'd do justice by trying to summarize what it says, so I hope the people that are interested in discussing this topic have access to the article (it's available at ScienceDirect, if you have access to that.)
So, is the article right? If it is, can the Carnot efficiency be applied to any physical system that produces work, and not just fuel cells?
I'd appreciate to hear your thoughts, thanks. :biggrin:
Science news on Phys.org
The title doesn't imply to me that they applied a Carnot efficiency calculation to a fuel cell - and I'm not sure how you would (just look at the equation!). No, carnot efficiency applies to heat engines only.
Hey, thanks for answering. :smile:
Well, your particular question is addressed in section 4 of the article. They state:
Andrew E. Lutz said:
The Carnot efficiency is a ratio of temperatures, while the fuel cell efficiency is a ratio of energy changes for a reaction. The question is: how do we make a direct comparison of these different expressions?
The first thing they do to answer the question is to consider the high temperature reservoir:
We can begin to compare the Carnot cycle to a fuel cell by recognizing that the high temperature reservoir is generated by the release of chemical energy.
They then introduce a modified heat engine, where the high temperature reservoir is replaced by a combustion reactor.
The reactor takes in fuel and oxidizer, and exhausts a product mixture; the operation must be steady-state in order to supply heat to the working fluid in the continuous cycle. The reactor temperature is constant, consistent with the Carnot cycle for the working fluid.
In the associated sketch, the high temperature reservoir has H2+O2 going in it, a ΔH_R being produced where the high temperature reservoir is, and H2O coming out. The rest of the engine is a typical heat engine, with a cycle producing work and a low temperature (cold) reservoir receiving heat from the cycle.
They then state that to obtain the maximum Carnot efficiency, we want the highest temperature possible in the reactor. This will happen when the change in Gibbs free energy vanishes.
[tex]\Delta G_R = 0 = \Delta H_R - T \Delta S_R[/tex]​
With this in mind, they then define a combustion temperature T_C, that is
[tex]T_C = \left. \frac{\Delta G_R}{\Delta S_R} \right |_{T_C}[/tex]​
Now with this temperature in mind, they apply the First law to the reactor to arrive at
[tex]Q_H = -\Delta H_R (T_C)[/tex]​
Juggling around with the Second law, they arrive at the other additional result:
[tex]Q_L = -T_L \Delta S_R(T_C)[/tex]​
where [tex]T_L[/tex] is the temperature of the cold reservoir.
So,
[tex]\eta_{\text{Carnot}} = \frac{Q_H - Q_L}{Q_H} = \frac{\Delta H_R (T_C) - T_L \Delta S_R(T_C)}{\Delta H_R (T_C)}[/tex]​
This equation represents the efficiency of a Carnot cycle with heat input provided by an isothermal reactor operating at the maximum temperature sustainable. Both the enthalpy and entropy changes refer to the reaction at the combustion temperature, and the numerator looks like the change in Gibbs energy, except that the low temperature remains in the heat rejection term.
To finish showing the equivalence, the authors use an approximation.
The enthalpy and entropy of reaction are generally not strong functions of temperature.
So,
[tex]\Delta H_R (T_C) \approx \Delta H_R (T_L),[/tex]
[tex]\Delta S_R (T_C) \approx \Delta S_R (T_L).[/tex]​
Hence,
[tex]\eta_{\text{Carnot}} = \frac{\Delta H_R (T_C) - T_L \Delta S_R(T_C)}{\Delta H_R (T_C)} \approx \frac{\Delta H_R (T_L) - T_L \Delta S_R(T_L)}{\Delta H_R (T_L)} = \left.\left( \frac{\Delta G_R}{\Delta H_R} \right)\right|_{T_L}[/tex]​
Now, if we go back a bit, any process that takes in energy to produce work has a First law efficiency defined by
[tex]\eta = \frac{W_\text{out}}{Q_\text{in}}[/tex]​
For a fuel cell, both terms need to be evaluated with the help of the First law of Thermodynamics. Assuming a constant pressure process that is done with reversible heat transfer, and using the Gibbs free energy formula of H - TS, the authors arrive at
[tex]W_\text{out} = - \Delta G_R,[/tex]​
where
[tex]\Delta G_R = G(T, \text{Products}) - G(T, \text{Reactants})[/tex]​
This energy change is evaluated at the operating temperature of the fuel cell.
Which is presumably T_L from before.
The Q_in term is evaluated as the change in enthalpy for the reaction,
[tex]Q_\text{in} = - \Delta H_R[/tex]​
So we have
[tex]\eta_\text{fuel cell} = \frac{W_\text{out}}{Q_\text{in}} = \frac{\Delta G_R(T_L)}{\Delta H_R(T_L)} = \left.\left( \frac{\Delta G_R}{\Delta H_R} \right)\right|_{T_L}[/tex]​
Having finished their proof in section 4, the authors state
This derivation shows that the Carnot cycle operating on a reaction is limited by the same maximum efficiency as a fuel cell. The derivation defined the combustion temperature in a unique way. It also invoked the assumptions that the changes in enthalpy and entropy across the reaction are independent of temperature.
They then go on to analyze some example reactions to show a good agreement between their derivation and what the actual calculations yield.
So, is this derivation any good, or are there any flaws?
I hope this helped, and I hope I didn't copy and paste too much to warrant a copyright infringement! :-p
10K
