Refreshing help needed with calculation of torque of gear wheel
The discussion focuses on calculating the torque of a cylindrical gear wheel with a radius of 1.5 cm and a length of 2.5 cm, which is subjected to a sudden stop by a locking bolt. The user, Ryan, seeks assistance in determining the moment of inertia for the gear, as it is not a standard shape. The torque formula T = I*a is highlighted, emphasizing the need to calculate angular velocity from the given RPM and to approach the moment of inertia by decomposing the gear into ideal shapes such as rings and discs.
  • Understanding of torque and angular deceleration
  • Familiarity with the torque formula T = I*a
  • Knowledge of moment of inertia calculations
  • Basic principles of rotational dynamics
  • Learn how to calculate moment of inertia for composite shapes
  • Study the principles of rotational dynamics in engineering
  • Explore torque calculations in mechanical systems
  • Investigate the effects of sudden stops on rotating objects
Engineering students, mechanical engineers, and anyone involved in rotational dynamics or torque calculations in mechanical systems.
Fjolvar
Hello,
I'm working on calculating a torque value for an engineering project at a new internship I started. Basically there is a spinning gear wheel similar to the picture I posted below (but thicker/cyclindrical), and I need to calculate the force or torque applied on a locking bolt that will suddenly engage at about 1/2*r of the gear bringing it to a complete stop.
http://thehobbyshop.co.za/images/LOWER_GEAR_WHEEL.jpg
The radius of the wheel (which is cylindrical in shape) is approximately 1.5cm with a length of about 2.5cm. I'm given the RPM which is a constant speed, so from that I can calculate the angular velocity. After the bolt engages, the velocity will change to zero creating a deceleration that I can plug into the torque formula T= I*a.
Would I have to then calculate the moment of intertia in order to solve the equation, and if so, how would I approach this? I've only solved inertia problems with ideal shapes.. not oddly shaped gears. Any help would be greatly appreciated! Thanks in advance..
-Ryan
So basically I just need to calculate the torque of a spinning gear wheel. Any ideas from anyone?
To calculate moment of inertia, can you not see the gear wheel as a sum of ideal shapes? You could disregard the teeth and see the outer rim as a ring, the inner part as a disc, and the connections between them as rods or planes.
  • · Replies 27 ·
22K
24K
  • · Replies 17 ·
12K
