How Do You Calculate Car Weight and Required Motor Force?
  • Thread starter Thread starter Jessi
    Force Science
The discussion revolves around calculating the weight of a car and the force required for its acceleration. The subject area includes concepts from mechanics, specifically relating to mass, weight, and Newton's second law of motion.
  • Mixed
  • Participants explore the calculation of weight using mass and gravitational acceleration. There is an attempt to determine the force required for acceleration, with some confusion regarding the application of formulas and units of measurement.
The discussion has seen participants checking each other's work and providing corrections. Some guidance has been offered regarding the correct application of Newton's second law, and there is an ongoing exploration of the relationship between mass, force, and acceleration.
Participants express uncertainty about the units involved in their calculations and the relevance of weight to the problem at hand. There is a focus on ensuring that the correct formulas are applied and understood.
Jessi
I was just hoping someone could check the work I did on this two part problem? :)
18a. A car has a mass of 1200 kg. What's the weight of the car?
Answer: 1200 kg*9.8 m/s^2 = 11760 N.
b. Disregarding friction, what force must the car motor apply to accelerate the car along a level highway at the rate of 4.0 m/s^2?
Answer: 11760 N/4.0 m/s^2 = 2940 kg.
Thanks so much in advance!
Right!
No. You need to use F = ma. (Note that force must have the units of force, which is N. Mass (measured in kg) is not a force.)
Oh, okay! :) Thank you for helping me.
So is it 11760 N*4.0 m/s^2 = 47040? I don't understand what the unit is, though - I thought I'd already used N in the problem, so it had to be mass. Does that not matter?
No! This problem has nothing to do with the weight of the car.
Use F = ma, which means:
Force needed to accelerate car = (mass of car) x (acceleration).
The answer will be in N, the unit of force.
Alrighty!
1200 kg (mass of car)*4.0 m/s^2 (acceleration) = 4800 N?
*hopeful*
Yes, that's right.
Wonderful! Thanks, both of you.
  • · Replies 20 ·
