Fortran alternative to Matlab 'system' command
The discussion focuses on executing a Linux executable from Fortran code, specifically Fortran 77. The user is unable to replicate the Matlab 'system' command functionality in Fortran, where './' is not working. A key insight is that the './' prefix is a Unix convention indicating the current directory, and if the executable is not found, the full pathname must be specified instead, such as '/mnt/hd1/usr/mushi/bin/filename'. The conversation highlights the need for clarity on the correct command to use in Fortran for executing external programs.
  • Understanding of Fortran 77 programming
  • Familiarity with Unix/Linux command line operations
  • Knowledge of executable file paths in Unix
  • Basic understanding of how system calls work in programming languages
  • Research the Fortran 'system' command and its alternatives
  • Learn about executing external commands in Fortran using 'execute_command_line'
  • Explore Unix/Linux file path conventions and how they affect program execution
  • Investigate error handling in Fortran when executing external programs
Fortran developers, programmers transitioning from Matlab to Fortran, and anyone needing to execute external executables within Fortran scripts.
mushi
Hi,
I have been trying to run a linux executable (written in fortran77) into my another code (also in fortran77). In Matlab, I did it with "system('./<filename>')". But I am not able to do it in fortran script as './' is not simply working for me.
I will really appreciate if anyone could tell me what alternative command I can use to execute an executable file into fortran code. A quick response will be extremely helpful and highly appreacited.
Thanks in advance.
mushi
The command (if there is one in your Fortran) may not be "system()" but I have no idea of other possibilities. The "./" prefix is nothing to do with the language; it's a shortcut in Unix that says the executable is located in the current directory. So if the executable is not located in what the op sys will see as the current directory, you should specify the full pathname instead, e.g., '/mnt/hd1/usr/mushi/bin/filename'.
  • · Replies 18 ·
11K
  • · Replies 20 ·
13K
