Solving Shunt Series-Series Feedback Problem: Help Needed | Angelfire
  • Thread starter Thread starter geelude
    Feedback
The discussion focuses on solving a shunt series-series feedback problem in amplifier design. Key points include the use of negative voltage feedback to stabilize closed-loop gain, reduce nonlinear distortion, and control input and output impedance. The conversation highlights the advantages and disadvantages of negative feedback, particularly its impact on gain and noise reduction. Additionally, it emphasizes the importance of careful design to prevent oscillation in feedback circuits.
  • Understanding of feedback mechanisms in amplifier circuits
  • Familiarity with series and shunt configurations
  • Knowledge of operational amplifiers (Op-Amps) and their frequency response
  • Basic concepts of impedance matching in electronic circuits
  • Research the design principles of operational amplifiers and their feedback configurations
  • Learn about the effects of negative feedback on amplifier performance
  • Explore techniques for impedance matching in RF applications
  • Investigate methods to prevent oscillation in feedback circuits
Electrical engineers, circuit designers, and students studying amplifier design and feedback systems will benefit from this discussion.
geelude
Hey guys,
I am currently solving a problem involving shunt series-series feedback. So far this is what I can say about the circuit:
- Series mixing is feedback combined with source
- Negative voltage feedback samples output voltage
- Series voltage feedback stabilises close loop gain and should be used to get precise voltage gain
- Negative feedback has disadvantage of reducing gain of amp but can be overcome by extra stages of amplifier
- Advantages are stabilises gain, reduction in nonlinear distortion, reduction in noise and also controls input and output impedance
- Unwanted noise coming from power supply, coupling of signals from other circuits, feedback can only reduce thermal and shot noises
- In voltage feedback input terminals of the feedback network are in parralel with the load and output voltage appears at the input terminal of feedback
- A way to test for voltage feedback is to see if signal vanishes as short circuit
- As series voltage feedback stabilises close loop voltage gain it is good for designing amplifiers with precise voltage gainse
- Negative feedback factor is larger than unity therefore negative series feedback increases input impedance
- Negative voltage feedback reduces output impedance
Can anyone else help me out, what else can I add and say about this feedback network?
The link to the problem is as follows:
http://www.angelfire.com/electronic2/helpneed/index.html
Please help!
Thanks!
extra and important point
In many circuit applications feedback is used to help fix input and output impedances . Typically shunt will reduce the impedance to low values , so that an external but well defined resistor then defines the (say ) input impedance.
Series does the opposite
. It is possible to use a combination to define an accurate matching impedance (say 50 ohms) without ever using a 50 ohm resistor and hence gain a noise advantage.
One of the most important uses is to linearise a circuit -- most transistor circuits are inherently non-linear ( not all) -- the transfer funtion io/vi
is partly diode characteristic dependent ( exponential ) but also beta dependent ( i.e. transfer efficiency ) , so that for linear applications ( Audio amplifiers , or instrumentation ) you must use feedback to overcome this.
The limitations of these techniques is that unless carefully designed they can oscillate , to avoid this the internal amplifier is usually rolled off in gain at a 6db/octave rate -- Opamps are a good example where a single capacitor dominates the roll off .
This has the effect of reducing the amount of feedback with frequency
so severly limits the 'useful' range where the feedback is effective.
  • · Replies 50 ·
  • · Replies 26 ·
  • · Replies 20 ·
