Convert muscular energy to electricity
The discussion revolves around the conversion of muscular (mechanical) energy to electrical energy without the use of traditional generators. Participants explore various methods and devices that could achieve this conversion efficiently, focusing on alternatives that do not involve rotating shafts or gears.
  • Experimental/applied
  • One participant questions the feasibility of converting muscular energy to electricity without using a generator, suggesting that any conversion mechanism would inherently be a generator.
  • Another participant clarifies that they seek a small device for conversion that does not involve rotating components.
  • Some participants mention the "forever flashlight" as an example of a device that converts mechanical energy to electrical energy through linear motion.
  • A suggestion is made to use piezoelectric crystals to capture energy from footsteps, although concerns about their efficiency are raised.
  • There is a discussion about the practicality of using piezoelectric generators, with references to research indicating low power output and the need for energy storage solutions.
  • One participant expresses skepticism about the efficiency of piezoelectric devices for generating sufficient power for applications like street lighting.
  • Another participant proposes the idea of linear generators, which could be attached to boots to harness energy from movement.
Participants express differing views on the practicality and efficiency of various methods for converting muscular energy to electricity. There is no consensus on a single effective solution, and multiple competing ideas are presented.
Participants note limitations regarding the efficiency of piezoelectric devices and the practicality of generating sufficient power for specific applications, such as street lighting. The discussion highlights unresolved questions about the feasibility of different energy conversion methods.
This discussion may be of interest to those exploring alternative energy generation methods, particularly in the context of wearable technology and energy harvesting from human movement.
mafik66
Hi to all physicists
How can convert muscular (mechanical) energy to electricity without using a generator?
In fact I am looking for a way to convert muscular energy to electricity energy without use the generator.
You can't, technically. Anything that converts another form of energy to electricity is a generator.
If you're referring to myoelectric signals, as are used in controlling prosthetic devices, that isn't conversion. It's merely detection of what is already electricity.
thanks for answer.
but let's make my question more clear, I want to convert muscular energy into electrical energy, with highest efficiently
and i need a small device (generator) to this purpose. which don't have Rotating shaft and gears?
are there the generator don't have Rotating shaft and gears?
Sure. The forever flashlight does what you describe.
I have one of those! My boss at my last place of employment gave it to my mother several years ago. It's weak, and takes a lot of pumping, but it's a lot better than being in the dark.
A piezoelectric crystal in the heel of each shoe can do this. Or just click your gas lighter a lot of times. Or comb the cat.
in forever flashlight the magnet slides back and forth through the coil and generated a pulse of electricity in the coil, in fact the system is linear motion. well can do this motion system in Rotational motion (clockwise and counterclockwise motion together) without Neutralization of current?
thanks but piezoelectric crystal don't have enough efficiency for convert to electric
What have you got against rotation?
mafik66, You are not alone in trying to generate useful power from piezoelectric generators, both crystalline and flexible film types. Here is a selection of products where they are useful. The last reference is the report of research to generate and store electrical energy. The researchers report it is NOT practical. DARPA has paid for several projects for soldiers to recharge their batteries by walking, etc., all without practical success. If you discover how to do this using muscle power, more power to you.
http://www.imagesco.com/catalog/sensors/piezo.html
POWER GENERATION, page 71
www.imagesco.com/articles/piezo/piezo00.html
www.metrolog.net/.../piezo.../piezofilm_energy_generation_II_enus_...
"The investigation shows that the power output from a single piezo-film was very low in the range of 0.2 W. Therefore, direct application of the piezo-film as a power source is not practical. It is unavoidable to use a storage device to collect the weak power output for future usage. Fortunately, the voltage outputs from a single piezo-film can produce a root-mean-squared voltage of 1.18 V which is high enough to store the generated electricity into a small nickel metal hydride battery."
www.wwwsst.ums.edu.my/data/file/SqD1WjfN7sf2.pdf
is it efficient for me to use a piezoelectric crystal to capture the energy from the footstep of walking people and store it,for later use(light up the street lights)
elric, Welcome to Physics Forums!
Research into soldiers generating power while walking using piezpelectrics has been done. The amounts of power are small, but are usable for recharging radio batteries, for instance. See:
US Army's Boot-Based Energy Harvester Lightens Soldier's Load
11/21/2011
http://www.designnews.com/author.asp?section_id=1365&dfpLayout=blog&dfpPParams=ht%5F13%2Cindustry%5Falt%2Cindustry%5Fgov%2Caid%5F235935&doc_id=235935&image_number=1
As for the second part of your question: storage and use to light up street lights: battery technology is improving the energy density storage capacity, but only gradually. Street lights use LARGE amounts of power, so probably human footsteps during walking just wouldn't generate enough power to light up the streets.
Cheers,
Bobbywhy
perhaps you could also use linear generators (magnet sliding along a spool), you could attach them to the side of boots
Muscle power performs my job.
I get paid.
I pay my power bill.
  • · Replies 74 ·
11K
  • · Replies 0 ·
  • · Replies 72 ·
11K
  • · Replies 16 ·
  • · Replies 30 ·
