Solve Math Doubt: Why Did This Happen?
  • Thread starter Thread starter iZnoGouD
    Doubt
The discussion revolves around the mathematical concept of limits, particularly in the context of expressions that involve division by zero. Participants explore the implications of such expressions, the use of l'Hôpital's rule, and the nature of indeterminate forms. The scope includes theoretical reasoning and mathematical reasoning.
  • One participant expresses confusion about why division by zero is attempted, labeling it as nonsensical.
  • Another participant explains the use of l'Hôpital's rule to evaluate limits that result in indeterminate forms like 0/0.
  • A different participant questions the rationale behind dividing by zero, suggesting it is nearly nonsensical but acknowledges the potential for limits to yield meaningful results.
  • One participant discusses the application of the sinc function in digital signal processing, indicating that division by zero has practical uses in that context.
  • Several participants clarify that they are not actually dividing by zero but rather approaching it through limits, emphasizing that limits can lead to well-defined values despite the indeterminate forms.
  • There is a reiteration that the discussion is about limits, and that the concept of dividing by zero is not being directly applied.
Participants express differing views on the validity and rationale of dividing by zero, with some arguing against it while others highlight its utility in specific mathematical contexts. The discussion remains unresolved regarding the philosophical implications of division by zero.
Some participants acknowledge that their understanding may be limited by their educational background, which could affect their interpretations of the mathematical concepts discussed.
iZnoGouD
can you explain why this happen? i can't understand
thks in advance
Mathematics news on Phys.org
They're kinda the same thing...
[itex]\frac{1}{0} = \infty[/itex]
[itex]\sin^2(0) = 0[/itex]
so
[itex]\frac{\sin^2(0)}{0} = \underbrace{\frac{0}{0}}_\text{ind.} = \frac{1}{0}\cdot\frac{0}{1} = \underbrace{\infty\cdot0}_\text{ind.} = \frac{1}{0}\cdot\frac{\sin^2(0)}{1}[/itex]
Use l'Hôpital's rule to find the value for this limit.
If [itex]\lim\limits_{x\to\alpha}\frac{f(x)}{g(x)} = \frac{0}{0} \mathrm{or} \pm\frac{\infty}{\infty}[/itex], then [itex]\lim\limits_{x\to\alpha}\frac{f(x)}{g(x)} = \lim\limits_{x\to\alpha}\frac{f'(x)}{g'(x)}[/itex]
so, define functions...
[itex]f: x \ {\mapsto}\ \sin\left(\frac{1}{2} \, x\right)^{2}[/itex]
[itex]g: x \ {\mapsto}\ x^{2}[/itex]
Differentiate until you aren't going to get an indeterminate value (that is, make sure that the denominator does not equal zero).
[itex]\frac{\mathrm{d}g}{\mathrm{d}x} = 2 \, x[/itex]
[itex]\frac{\mathrm{d}^{2}g}{\mathrm{d}x^{2}} = 2[/itex]
So now the denominator will never equal zero. Differentiate [itex]f[/itex] the same number of times.
[itex]\frac{\mathrm{d}f}{\mathrm{d}x} = \sin\left(\frac{1}{2} \, x\right) \cos\left(\frac{1}{2}<br /> \, x\right)[/itex]
[itex]\frac{\mathrm{d}^{2}f}{\mathrm{d}x^{2}} = -\frac{1}{2} \, \sin\left(\frac{1}{2} \, x\right)^{2} +<br /> \frac{1}{2} \, \cos\left(\frac{1}{2} \, x\right)^{2}[/itex]
Now divide the functions
[itex]\frac{f''(x)}{g''(x)} = -\frac{1}{4} \, \sin\left(\frac{1}{2} \, x\right)^{2} +<br /> \frac{1}{4} \, \cos\left(\frac{1}{2} \, x\right)^{2}[/itex]
simplifies to
[itex]\frac{f''(x)}{g''(x)} = \frac{1}{2} \, \cos\left(\frac{1}{2} \, x\right)^{2} -<br /> \frac{1}{4}[/itex]
now take the limit as [itex]x[/itex] tends to zero
[itex]\lim\limits_{x\to0}\frac{1}{2} \, \cos\left(\frac{1}{2} \, x\right)^{2} -<br /> \frac{1}{4} = \frac{1}{2} \, \cos\left(0\right)^{2} -<br /> \frac{1}{4} = \frac{1}{2} - \frac{1}{4} = \frac{1}{4}[/itex]
And, to bring it all together:
[itex]\lim\limits_{x\to0}\dfrac{\sin^{2}\left(\frac{x}{2}\right)}{x^{2}} = \lim\limits_{x\to0}\frac{1}{2} \, \cos\left(\frac{1}{2} \, x\right)^{2} -<br /> \frac{1}{4} = \frac{1}{4}[/itex]
I hope that helps!
I still don't understand why people want to divide by zero. It's completely nonsense...
Hey, I've never understood why people want to eat Haggis!
People continue to act irrationally!
It's sort of completely nearly nonsense... If the limit of whatever/x as x->0 is the same from both sides, then I call that close enough as long as it's not part of some weird "1=0" abuse of math. It is possible that I just haven't taken enough classes to know that I'm wrong, though.
Digital signal processing makes uses of poles and the [itex]\mathrm{sinc}(x)[/itex] function.
The normalized [itex]\mathrm{sinc}(x)[/itex] function:
[itex] \mathrm{sinc}(x) = \left\{<br /> \begin{array}{cc}<br /> 1 & \text{if} \quad x = 0\\<br /> \frac{\sin(\pi \, x)}{\pi \, x} & \text{if} \quad x \neq 0<br /> \end{array}<br /> \right.[/itex]
Has uses in DSP as its Fourier Transform is the rectangle function, which is the ideal low-pass filter.
[itex] \mathrm{rect}(\xi) = \mathcal{F}_t\left[\frac{\sin(\pi \, x)}{\pi \, x}\right]\left(\xi\right)[/itex]
Poles in filters determine the Q-factor, or bandwidth of the filter. I think, anyway. Or what frequencies a filter affects. I don't remember, I read some college DSP notes when high school trig was getting boring, so it went over my head a little.
[itex] \dfrac{\omega^{3} - 17 \, \omega^{2} + 94 \, \omega - 168}{\omega^{3} - 14 \, \omega^{2} + 51 \, \omega<br /> - 54} = \dfrac{{\left(\omega - 7\right)} {\left(\omega - 6\right)} {\left(\omega -<br /> 4\right)}}{{\left(\omega - 9\right)} {\left(\omega - 3\right)} {\left(\omega -<br /> 2\right)}}[/itex]
The above has zeros at [itex]\omega = \left[7, 6, 4\right][/itex] and poles at [itex]\omega = \left[9, 3, 2\right][/itex].
Division by zero has its uses. I'm not sure outside of DSP, though.
You're not actually dividing by zero. You come close to dividing by zero, never do, and the ratios of the two functions that are heading to zero, that ratio may actually head towards a well-defined number.
Sorry to burst your "ooh, there's a rip in the space-time continuum" bubble.
This is true. But we are talking about limits, so I figured that that was implied.
Again, there's no dividing by 0, just taking a limit. So with the greatest possible respect, shaddap. There's a lot of stuff taking limits is useful for, and if plugging in happens to result in 0/0, it's just one you can't solve by just plugging in.
  • · Replies 30 ·
  • · Replies 30 ·
