Analyzing a 7-variable data set where multiple variables changed at once
The discussion revolves around analyzing a 7-variable data set related to the growth of thin films under varying conditions. Participants explore the challenges of formulating hypotheses and predicting outcomes based on the data, which lacks a clear structure and statistical significance.
  • One participant expresses uncertainty about the statistical significance of the data and seeks software recommendations for analysis.
  • Another participant notes the lack of a clear hypothesis and suggests that understanding the underlying physics could aid in formulating predictions.
  • Participants discuss the difference between determining statistical significance and making predictions, with one emphasizing the need for a consistent measurement of film quality.
  • There are suggestions to consider optimization techniques and to potentially fit a linear model with higher-order terms to the data.
  • One participant mentions that others in the group have successfully reproduced good films under certain conditions, implying the existence of patterns in the data.
  • Concerns are raised about the feasibility of collecting more data due to training limitations on the necessary equipment.
Participants do not reach a consensus on how to analyze the data or the best approach for making predictions. Multiple competing views on the methodology and the significance of the data remain present throughout the discussion.
Limitations include the lack of a clear hypothesis, the variability in growth conditions, and the potential for missing assumptions regarding the underlying physical principles affecting the outcomes.
swooshfactory
Hi,
I have some experimental data from a colleague which has been collected with different values for 7 parameters. It isn't nice, as in it's not as if 6 of the parameters were held fixed while the seventh was adjusted. Beyond that, I don't have much data. I'm not up on my statistical significance, but this data will probably prove to not be significant.
I'm wondering if there is some software that would take a shot and analyzing this data and maybe indicate some trends.
Thanks for reading!
You haven't explained enough about the data for anyone to know what hypothesis about it you wish to test.
Ok, my apologies. The data is for growing thin films with different growth conditions. Some of the sets of variables produce "good" films, some "mediocre" and some "bad". I cannot formulate a hypothesis based on the data - the conditions seem so different from one data set to the next.
I would like to be able to predict which conditions will produce good films. If more information is needed, I will gladly supply it.
Matt
There are two different goals in your previos posts. The question of determining "statistical signifcance" is much less ambitious that the goal of making good predictions. In the usual sort of statistical testing, one often assumes a "null hypothesis" that essentially says "The conditions don't affect the outcome". One analyzes the probability of the data based on that very unpredictive model. If the probability is low then one may subjectively "reject" the null hypothesis. However, this procedure merely decides that the conditions do affect the outcome without specifying exactly how you can use the conditions to make a prediction.
As to making predictions, I think there are forum members who could advise you if present the data. (I'm not sure that I'm one of them.) It would also be helpful to know any basic physics that underlies the process.
Matt
Hi Matt,
This seems an optimization problem but Mr. Tashi is right; since there are a myriad of optimization techniques more details about your project would be helpful to determine which one better suits you.
Is there an underlying physical model you can adjust your data to? Are there economical constraints upon the value of the seven parameters (e.g. the lower one parameter the cheaper the process)? Would you be able to gather more data if necessary and, if you could, there are limitations in time or money to do it?
But anyway, at first sight you may try to fit some linear model with quadratic higher order terms and then, if the model fits nicely, simply check for the optimal solution in that model.
And about software to do these analysis, I would recommend you R (http://cran.r-project.org/). R is a very powerful language for statistical analysis and you'll be able to analyze your data in many different ways.
Thank you both for your replies. Overall, there must be some pattern (I would think), since other people in my group have said that they can reproduce good films using certain conditions. The data I have, though, is from someone exploring many different growth conditions.
Some of the physical principles would be something like high temperatures destroy order.
The price is assumed to be the same for each process, but I will consider this in my review.
More data could be collected, but I'm not trained on this machine, so it's possible it won't be for a while.
Thanks again...
Matt
Thanks again...
Matt
Well, then you could give a try to the lineal model and see how it goes. It will also give you hints on what parameters are more important for the quality which, by the way, you need a consistent way to measure it. So good luck!
  • · Replies 27 ·
