Speed of electric spark, arc and conductive ionized gas
The speed of electric sparks and arcs in vacuum and ionized gases is significantly less than the speed of light. Charged particles, primarily electrons, travel at a few percent of light speed, influenced by device design factors such as plate separation and potential difference. In contrast, lightning bolts can exceed speeds of 100,000 miles per hour. In ionized gases, the charge transfer occurs without the need for the molecules to physically move between electrodes.
  • Understanding of charged particles and their behavior in electric fields
  • Familiarity with vacuum tube technology and its components
  • Knowledge of ionized gases and their electrical conductivity
  • Basic principles of electromagnetism and electric current flow
  • Research the principles of electron mobility in vacuum tubes
  • Explore the design and operation of thyratrons and their applications
  • Study the physics of lightning and its electrical characteristics
  • Investigate the effects of potential difference on particle speed in conductive materials
Physicists, electrical engineers, and students studying electromagnetism, as well as anyone interested in the behavior of electric sparks and arcs in various mediums.
AlSo
Dear colleagues,
If an arc or a spark traveling in vacuum is actually the electrons jumping across vacuum, do they travel at near light speed?
From another point of view, devices like thyratrons use ionized gas molecules to conduct electricity, at what speed are those ionized molecules travelling? Do the molecules need to travel at all?
Thanks!
Allan
As you suspect, sparks consist of charged particles...often electrons, as in vacuum tubes, but any charged particles will do...as in ionized gases...even ionized air! They do NOT move anywhere near as fast as light which is electomagnetic radiation...maybe a few percent the speed of light. The actual speed of the charged particles depends on the design of the device, such as the separation distance of the charged plates and the potetial difference between charged plates.
I do not know typical speeds in vacuum tubes, but everyday lightning bolts [flashes] move at well over 100,000 miles per hour.
Thanks, for ionized gas I guess it is only the charge being transferred between molecules, and it is not necessary at all for the molecules to move from one plate to another. As for vacuum, I don't understand what slows the electrons down, I suppose a current flows through a wire at near the speed of light.
  • · Replies 0 ·
17K
