Why Doesn't the Water Level Decrease When an Ice Cube Melts?
The discussion revolves around the phenomenon of a floating ice cube in water and the implications of its melting on water level. Participants explore the relationship between the density of ice and water, and the principles of buoyancy as described by Archimedes.
  • Participants examine the idea that the weight of the ice cube equals the weight of the water displaced, questioning how this relates to the volume of water after melting. There is also inquiry into whether submerging the ice affects the water level.
The discussion is active, with participants presenting different interpretations of the principles at play. Some guidance is offered through references to Archimedes' principle, but no consensus has been reached regarding the implications of melting ice on water level.
Participants are considering assumptions about density and displacement, as well as the effects of external factors like submersion on water level. There may be constraints related to the clarity of the problem setup and the definitions being used.
Sam2847
Consider a floating ice cube in a glass of water.
I know that the weight of the ice cube is equal to the weight of the water displaced.
This would mean that if the ice cube melted, the volume of water melted would be less than the volume of the ice cube, because ice has a lower density than water. As a result, the volume of water in the glass should decrease.
If this is the case, then why does the water level in the glass remain the same, rather than decreasing?
*Does it have something to do with the part of the the ice cube floating above water, which would account for the greater volume before melting? That way the total volume would still decrease after melting, but the water level would still remain the same.
No, *yes
does the water level change measurably if you submerge the ice with a safety pin?
Proposition 5 of Archimedes' treatise On Floating Bodies states that:
Any floating object displaces its own weight of fluid.
— Archimedes of Syracuse[2]
Volume displaced = volume submerged.
Volume displaced = ice converted to water. Since the weights are the same.
  • · Replies 21 ·
  • · Replies 23 ·
12K
