Comparing Coldness: ICE vs WATER at 0°C
  • Context: High School
  • Thread starter Thread starter DhruvKumar
    Cooler
The discussion centers on the comparative coldness of ice and water at 0°C, exploring factors that influence the perception of coldness despite both being at the same temperature. The scope includes conceptual reasoning and personal experiences related to thermal conductivity and heat transfer.
  • Some participants propose that ice feels colder because it absorbs more energy as it melts, despite being a poor conductor of heat.
  • Others argue that ice conducts heat from the mouth more quickly than water, leading to a perception of greater coldness.
  • A participant suggests that the sensation of coldness may diminish with continued exposure, as experienced with ice cream, indicating a potential psychological factor in temperature perception.
  • Another viewpoint highlights that the rate of heat transfer is significant; ice may take longer to melt, while water quickly transfers heat, affecting the sensation of coldness.
  • One participant draws an analogy to the 'wind chill factor,' suggesting that the movement of heat away from the body can influence perceived temperature.
Participants express differing opinions on whether ice or water feels colder, with no consensus reached. Various factors such as heat transfer rates and psychological effects are debated without resolution.
Participants mention concepts like enthalpy of fusion and latent heat, which may require further clarification or assumptions about thermal dynamics that are not fully explored in the discussion.
DhruvKumar
ICE at 0 degree C and WATER at 0 degree C.
Which will appear more cooler to our mouth?
What factors determine the coldness of a body at same temperature.
Science news on Phys.org
Enthalpy of fusion for water is 79.72 cal/g. So ice is colder (it will absorb more energy). But ice cube is bad conductor of heat, therefore 1 g water at 0 degree C may feel cooler.
Good answer, but we can carry this thought experiment further to see that the ice will feel cooler because it will conduct heat from your mouth more quickly.
If you put water in your mouth it will immediately start to increase in temperature and feel less cool.
If you put zero degree ice in your mouth, it will immediately begin to melt. So now you have ice and water in your mouth, but everything stays at zero degrees.
can u convert it into easy words.
In easy words...
When a material such as water undergoes a change of state (eg ice to water or water to steam) some extra energy has to be added or removed even though the temperature remains unchanged. This energy has various names depending on what the states are and in which direction the change is taking place.
See also http://en.wikipedia.org/wiki/Latent_heat
So to the ice vs water question.
In the case of water: It takes an amount of energy to heat water from 0C to body temperature.
In the case of ice: It takes an amount of energy to turn the ice to water at 0C AND then an amount of energy to heat water from 0C to body temperature.
Ice feels colder because the mouth has to deliver this extra energy to the ice to melt it first.
In years gone past steam engine boilers were prone to exploding. Sure some people were killed by the explosion itself but the survivors had a worse fate... The escaping steam would condense on people releasing a lot of energy as it turns from water vapour at 100C to water at 100C. So people were in effect blasted with heat...and only then were they boiled.
When you boil a kettle you sometimes get a clear jet or water vapour emerging from the spout and then turning to steam an inch or so away. That clear bit you can't see is more dangerous than the steamy bit because it contains the extra latent heat.
The coldness we feel is determined by how quickly heat flows from us to the cold substance.
Ice at 0° Celsius will soak up a respectable amount of heat as it melts into water at 0°; it will feel colder... or at least that's what I feel when I try the experiment.
I may be wrong to say that water feels colder and I have not done experiment. But this is what I thought:
When you eat ice cream, it is first few spoons of ice cream that feel colder. Then your mouth being cold is less sensitive to temperature or you are kind of used to coldness in mouth so you don't feel next spoons as cold as first one.
In case of ice vs water, what matters is how long is time for heat exchange. If you take ice cube of 8 ccm in mouth and think of all time till it melts, first few seconds are significant for feeling coldness. If you take 8 ccc of water at 0 degree C, lot of heat transfer happens in just a second or two. Water touches entire mouth at one go and hence rate of heat transfer is faster. Hence colder feeling.
Again, this is personal opinion, may be wrong.
This is analogous to the 'wind chill factor' whereby stationary cold air doesn't make you as cold as moving air at the same temperature - heat is removed faster so there is a steeper temperature gradient near the surface of your skin and the temperature sensors (below the surface) are actually at a lower temperature and they tell you.
  • · Replies 16 ·
  • · Replies 38 ·
