| New Reply |
Metacentric height |
Share Thread |
| Jun20-12, 09:42 AM | #1 |
Metacentric height
hi
i am on to understand when ships are in a stable position. now i found that this is directly linked to a quantity called the metacentric height? there are two major forces, the gravitational and the buoyant force. and in classical mechanics when i wanted to find out the torque that results from two forces i looked at the distance between them and when they where parallel and equal in magnitude torque was given by D= r x F for which reason do i look at this metacentric height, it does not seem plausible to me at all, can somebody say a few words about why you look at this distance and not the direct distance between the two forces? |
| Jun20-12, 08:30 PM | #2 |
Recognitions:
The trouble with the forces in flotation is that they shift around. Stability is about response to small changes. If a boat rolls in the water, it's obvious where its centre of mass moves to, but it can be less obvious how the centre of buoyancy moves.
Consider some simple case: - hemispherical hull The profile of the hull in the water does not change, so the centre of buoyancy remains below the centre of curvature. This makes it stable; if the hull has tilted to the right then the mass centre is now left of a vertical through the centre of curvature. - tall pole, vertical This is obviously unstable. When exactly vertical there is no torque, but the slightest perturbation will lead to a torque tending to accelerate the perturbation. A critical consideration is the cross-section of the hull at the water level. Metacentric height encapsulates this. |
| New Reply |
Similar discussions for: Metacentric height
| Usiing angles and height to calculate height/altitude of object | Differential Geometry | 0 | ||
| metacentric height | Introductory Physics Homework | 2 | ||
| Predicting adult height given current height, age and growth plate measurement | Set Theory, Logic, Probability, Statistics | 4 | ||
| please help calculate the metacentric height pontoon | Engineering, Comp Sci, & Technology Homework | 1 | ||
| Metacentric height correction due to free surface effect | General Engineering | 2 | ||
