New Reply
Motion 2 problems -- Tossing hay bales and baseballs
Share Thread
Jun20-12, 06:04 PM   #1
1. A hay-baling machine throws each finished bundle of hay 2.0 m up in the air so it can land on a trailer waiting 4.7 m behind the machine.
(a) What must be the speed with which the bundles are launched?
2. A baseball is popped up, remaining aloft for 6.3 s before being caught at a horizontal distance of 83 m from the starting point. What was the launch angle?
2. Relevant equations
1. x = 1/2at^2 +vot +x0
x-xo = d
2. vx = cos*vo
vy = sin*vo
3. The attempt at a solution
1. I used the distance and plugged it into the first equation but it is the wrong answer I believe.
2. I know that in the end I have to divdide vy by vx and take the arctan of that but I do not understand how to find vy and vx. Can someone explain to me step by and step and what that means?
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Jun20-12, 09:17 PM   #2
Recognitions:
Gold Membership Gold Member
Quote by blackraven View Post
Let's first talk about the vertical motion. At the maximum height, velocity is zero. Initially, the vertical velocity is vsinθ (a component of the initial velocity making an angle θ with the ground). You have initial velocity, final velocity, displacement and the acceleration.
Can you form an equation now?
Jun22-12, 06:59 PM   #3
This is going to sound like weird advice, but you're not thinking about the problem right. Don't think "I know that in the end I have to..." Just work through it.
Your equations are sound. Lets start with this: you know the maximum height right? What can you find with that if you know the acceleration of gravity?
Jun22-12, 07:17 PM   #4
[b]1
x-xo = d
2. vx = cos*vo
vy = sin*vo
ISEE Method
1. Identify
a) Only one object - the hay bale
b) The object doing 2 works. Going in horizontal and verical motion.
2. Select
y=y0+vy0ty+(1/2)ayty2
x=x0+vx0tx+(1/2)axtx2
Since it involves only one object,
ty=tx
3. Execute
4. Evaluate
New Reply
Tags
motion
Similar discussions for: Motion 2 problems -- Tossing hay bales and baseballs
Thread Forum Replies
Probability - Tossing a coin, counting X heads, then tossing X more times. Calculus & Beyond Homework 6
Projectile Motion problems (don't want answers to problems) Calculus & Beyond Homework 1
Influence of a humidor on the aerodynamics of baseballs General Discussion 5
[SOLVED] baseballs and impulses Introductory Physics Homework 2
fair die tossing problems Set Theory, Logic, Probability, Statistics 6
