New Reply
Find the tangent line that passes through the origin..
Share Thread Thread Tools
Jun20-12, 07:55 PM   #1
This problem is 2.95 of University Physics, 11th edition.
Catching the Bus: A student is running at her top speed of 5.0 m/s to catch a bus, which is stopped at the bus stop. When the student is still 40.0 m from the bus, it starts to pull away, moving with a constant acceleration of 0.170 m/s2.
There are subproblems a,b,c,d,e, and f; which I've all figured out except for f)
f) What is the minimum speed the student must have to just catch up with the bus?
2. Relevant equations
Let the subscript b mean bus, and let the subscript p mean student (p for pupil).
sp(0)=0 m
sb(0)=40 m
vp(t)=Unknown
The acceleration of the bus was given, I used calculus to find the velocity and position.
sb(t)=0.085t2+40 m
vb(t)=0.17t m/s
ab(t)=0.17 m/s2
3. The attempt at a solution
I modeled the problem by considering the bus and the student as point particles. The points in time where the student and the bus are at the same place are the intersections of the graphs of the position functions. The position function of the bus is known and given above, but the position function of the student is the integral of the student's velocity, which is constant.
The position function would be of the form sp(t)=v(t)*t+0
I managed to figure out that sp(t) must be the equation of the tangent line of sb(t) which passes through the origin.
How do I find the equation of the tangent line of sb(t)=0.085t2+40 m (And thus, the velocity) that passes through the origin?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Jun20-12, 08:42 PM   #2
Hmm, I didn't have to use calculus to solve this question. Set the displacements of the student and bus equal, then work from there.
Jun20-12, 09:04 PM   #3
I don't know the displacement without knowing the velocity...
Jun20-12, 09:05 PM   #4
I mean, take the equations of the displacement of the student and the bus, then set them equal.
Jun20-12, 09:24 PM   #5
You mean like so?:
sp(t)=sb(t)
-> v(t)*t=0.085t2+40,
-> v(t) =(0.085t2+40)/t
This tells me what the velocity would be at my intersection point, but I still don't have the time, t.
Jun20-12, 09:29 PM   #6
Yes, now what kind of equation do you have from there?
Jun20-12, 09:35 PM   #7
It's a rational equation that gives me the velocity of the student.. If I set that equal to the velocity function of the bus, I can find the time where they intersect!
0.17t=(0.085t2+40)/t
t=21.7 s.. Thank you so much!!!
Jun20-12, 09:45 PM   #8
Ha, I was actually going with a quadratic equation and setting √(v2 - 4ad) = 0, but your method works as well. =)
New Reply
Thread Tools
Similar Threads for: Find the tangent line that passes through the origin..
Thread Forum Replies
Tangent line that passes through origin Calculus & Beyond Homework 7
if every tangent line of a curve passes through a point, it is a line Differential Geometry 5
Find equation of line that is perpendicular to the tangent line to the curve Calculus & Beyond Homework 6
What's f'(1) if the line tangent to the graph of the function at (1,7) passes (-2,-2) Calculus & Beyond Homework 4
If the tangent line to y = f (x) at (9,7) passes through the point (0,6)... Calculus & Beyond Homework 2
