| New Reply |
1 = 0 <-- What goes fundamentally wrong? Delta distribution |
Share Thread | Thread Tools |
| Jun22-12, 09:14 AM | #1 |
[itex]2 \pi a = \iint \delta(a^2 - (x^2+y^2)) \mathrm d x \mathrm d y [/itex]
Differentiating both sides w.r.t. "a" (using chain rule on the RHS) gives [itex]\frac{\pi}{a} = \iint \delta'(a^2 - (x^2+y^2)) \mathrm d x \mathrm d y[/itex] Changing variables (and noting that integrand is independent of theta) [itex]\frac{\pi}{a} =2 \pi \int \delta'(a^2 - r^2) \cdot r \cdot \mathrm d r [/itex] Eliminate the pi on both sides, but more importantly we can rewrite the RHS as (using chain rule!) [itex]\frac{1}{a} = - \int \frac{\partial}{\partial r} \delta(a^2 - r^2) \mathrm d r[/itex] However the RHS is obviously zero, explicitly: [itex]0= \delta(a^2-r^2) \big|_{r=0}^{r=+\infty}[/itex]. DISCLAIMER: I know I use the delta as a physicist would, but please be flexible... I would really appreciate knowing where it essentially goes wrong. |
| Jun22-12, 09:59 AM | #2 |
Hmmm ... have you forgotten about the constant of integration at all? I don't know which region you're integrating over in the first equation, so I can't verify it.
| Jun22-12, 10:02 AM | #3 |
I think the very first equation is wrong. The delta function has units of 1/(units of argument). So delta(a^2 - x^2 - y^2) has units of [length]^-2. Thus the RHS of the first equation is unitless, whereas the LHS has units of length, so the equation can't be correct. I haven't worked it out, but I think if you are more careful you can evaluate the RHS of the first equation and it will be some pure number like 2*pi. Then of course differentiating that wrt a gives zero, as you found.
| Jun22-12, 10:18 AM | #4 |
1 = 0 <-- What goes fundamentally wrong? Delta distributionErr, you seem to be right... I'm totally flabbergasted. Integrating the delta-function on a circle over the plane does not give its circumference? How is that possible... |
| Jun22-12, 10:35 AM | #5 |
I think if you integrated the delta function delta(a - sqrt(x^2 + y^2)) you would indeed get the circumference. You have to recall that if f(x_0) = 0, the integral of delta(f(x)) scales inversely with f'(x_0). For example the integral of
delta(r - sqrt(x^2 + y^2)) is not the same as the integral of delta(100*[r - sqrt(x^2 + y^2)]) even though both arguments have zeros on the same circle in the plane. |
| Jun22-12, 10:42 AM | #6 |
Of course, thank you :)
| Jun22-12, 11:18 AM | #7 |
But... say we reinterpret the correct equation [itex]\pi = \int \delta(x^2+p^2-E) \mathrm d x \mathrm d p[/itex]. The RHS is by definition the (exponential of the) phase volume for a one-dimensional harmonic oscillator (2-dimensional phase space) with energy E.
So its entropy is independent of its energy? I.e. its temperature is infinite? Am I again overlooking something? |
| Jun22-12, 12:20 PM | #8 |
I'm not an expert on distributions. But one of my favorite books "Functional Analysis" by Lax says that [itex]\delta(x^2)[/itex] doesn't even have a sensible definition. Maybe that is what goes wrong?
| New Reply |
| Thread Tools | |
Similar Threads for: 1 = 0 <-- What goes fundamentally wrong? Delta distribution
| Change of variables for Delta distribution | Calculus | 20 | ||
| dirac delta-like distribution | Set Theory, Logic, Probability, Statistics | 6 | ||
| Dirac delta distribution | Calculus | 5 | ||
| mc(delta) t (What am I doing wrong?) | Biology, Chemistry & Other Homework | 3 | ||
| Integral involving delta distribution | Calculus & Beyond Homework | 1 | ||
