| New Reply |
Is oxygen that comes out from a car and regular oxygen the same (exactly identical) |
Share Thread | Thread Tools |
| Jun22-12, 06:23 PM | #1 |
Is oxygen that comes out from a car and regular oxygen the same (exactly identical) except that one is warmer than the other?
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Jun22-12, 07:29 PM | #2 |
How/where/when does oxygen come from a car?
| Jun22-12, 07:31 PM | #3 |
http://www.volkspage.net/technik/ssp/ssp/SSP_230.pdf
in diesel engines oxygen is one of the contributors |
| Jun22-12, 07:36 PM | #4 |
Oxygen is oxygen. Nothing sets one molecule apart from any others.
| Jun22-12, 07:38 PM | #5 |
so its not like atoms can have different levels of energy. I was just curious if a element is used in combustion does it use energy and is not the same or something like that
| Jun22-12, 07:43 PM | #6 |
The oxygen that comes out is not the same as ordinary oxygen, even stronger: it's not oxygen anymore at all! In the engine the oyxgen gets transformed to (among other things) carbon dioxide. It's this carbon dioxide that your car releases, and that is definitely not the same oxygen. It's very unhealthy to breath in carbon dioxide.
| Jun22-12, 08:08 PM | #7 |
Let's set a couple of things straight.
There is atomic oxygen and there is gaseous (molecular) oxygen. Atomic oxygen is exactly that - single atoms of the element oxygen, symbolized by O. Atomic oxygen loves to bond to virtually anything, including itself. Two oxygen atoms will bond and form O2 (O=O) as gaseous oxygen molecules. This is what we breathe. We rarely encounter atomic oxygen in every life. It is also possible for three oxygen atoms to bond to form O3 (O-O-O), which is called ozone, but I won't go into detail about that here. Now, according to that PDF (page 6, bottom graph), one of the byproducts (10%) of diesel combustion is indeed O2. This is everyday plain old breathable oxygen. So that's the answer to your question. However, an extremely strong note of caution: other byproducts of combustion are extremely toxic. Notably Carbon monoxide CO (C=O). This, just like oxygen, is odorless, colourless and highly mixable with oxygen. So, there is no practical way of separating oxygen from carbon monoxide. If you were to try to separate out oxygen from the exhaust, you would not separate the carbon monoxide, meaning you would be breathing it too. Carbon monoxide can kill you. Silently. You will never know it, you will just fall asleep. Do not do. |
| Jun23-12, 06:29 AM | #8 |
Mentor
Diesel engines similarly don't produce oxygen. They just don't use all of the oxygen in the air fed into the engine. They run on a lean air to fuel ratio. They have to do so because of the nature of how diesel engines work. |
| Jun23-12, 06:41 PM | #9 |
Recognitions:
![]() There isn't a whole lot of everyday talk about oxygen from car exhausts, but of course there are just as many oxygen atoms emerging from the exhaust as enter via the air filter and fuel*. Combustion is a conservative reaction: no atoms are created or destroyed, they merely change partners. There is no favouritism: isotopes are all treated equally. |
| Jun23-12, 06:59 PM | #10 |
Mentor
| Jun23-12, 07:15 PM | #11 |
The real dangerous gas - when it comes to any combustion source is carbon monoxide. It's an intermediary to the formation of carbon dioxide. If you're in an enclosed space and you have something like a malfunctioning gas burner, the carbon monoxide from it can kill you - and kill you really quickly. Carbon monoxide binds to the haemoglobin in your blood stream - stopping it from carrying oxygen. And if that happens, you fall asleep and then you die. It is dangerous. If you're ever using a gas burner indoors you need to have the room well ventilated. The carbon monoxide can build up and kill you before you know it. I know a terrible story about a family living in an old house - they had the windows redone, lots of insulation, but no design for ventilation. Used their gas heater - and died. One thing that drives me crazy with the whole global warming thing is people thinking carbon dioxide is a poisonous gas. It's possible the most important gas on the planet for the existence of life. I once had to tell a worried little friend, that carbon dioxide does not actually cause lung cancer. And that it is not always a man made gas. |
| Jun23-12, 07:59 PM | #12 |
Mentor
| Jun23-12, 11:02 PM | #13 |
Recognitions:
| New Reply |
| Thread Tools | |
Similar Threads for: Is oxygen that comes out from a car and regular oxygen the same (exactly identical)
| Why is there more oxygen? | General Astronomy | 6 | ||
| How come there is oxygen | Biology | 15 | ||
| Initial Mass of Oxygen + Mass of Oxygen leaked out | Introductory Physics Homework | 3 | ||
| Where did oxygen come from? | Biology, Chemistry & Other Homework | 6 | ||
| Oxygen | Earth | 2 | ||
