The use of the terms speed & velocity
  • Context: High School
  • Thread starter Thread starter swampwiz
    Speed Terms Velocity
The discussion focuses on the usage of the terms "speed" and "velocity" within the context of physics, exploring their definitions, historical context, and preferences in different communities. It includes considerations of both theoretical and conceptual aspects of these terms.
  • Historical
  • Some participants propose that "velocity" should be preferred as a vector term, while "speed" is a scalar term, although there are contexts where "speed" may still be appropriate.
  • One participant notes that a car's speedometer does not display negative values, yet the car can reverse, highlighting a nuance in the understanding of speed versus velocity.
  • Another participant mentions that physicists generally prefer to use "speed" for scalar quantities and "velocity" for vector quantities, while laypeople often use the terms interchangeably.
  • A question is raised about the historical origins of the term "speed" in physics, with references to Newton's use of "velocity" and the potential emergence of "speed" in the 18th, 19th, or 20th centuries.
  • It is noted that in Newton's time, the concept of vectors was not well developed, and "celerity" was used in contexts now associated with velocity.
  • One participant discusses the broader applications of the term "speed" today, indicating it can refer to various phenomena beyond motion, such as in mechanical or biological contexts.
  • There is a suggestion that the current convention of using "speed" for the magnitude of velocity may have originated at an unspecified time and place, prompting further inquiry.
  • A later reply references the origin of the word "velocity" from Norman French, contributing to the historical context of the discussion.
Participants express differing views on the appropriate contexts for using "speed" versus "velocity," with no clear consensus reached on the historical development or current conventions surrounding these terms.
The discussion reflects varying interpretations and applications of the terms "speed" and "velocity," with historical references that may not be fully resolved or agreed upon among participants.
swampwiz
The use of the terms "speed" & "velocity"
This is a interesting topic concerning when to use these two terms in a discussion. Of course, if it is a vector term, then velocity must be used - however even for a scalar term, velocity could still be used.
It seems to me that aside from the term of the speed of wave propagation (e.g., the speed of light, the speed of sound, etc.), or the measurement of the speed itself (although that measurement would simply give the velocity of that object), then the term velocity should be preferred - even if it is a scalar or applies to only one length dimension, including angular velocity for a planar system. With that said, I could still see speed used instead if talking about the motion of an object subject to set of holonomic constraints - e.g., a car on a roller coaster, or a point on a rotating wheel. etc. I could also see speed used in the term "instantaneous speed", even though it actually represents a vector quantity (in which case the speed would only represent the magnitude.) And of course in any talk about speed when really it means an inverse of the time required (e.g., computer speed, etc.) - rather than the proper parameter of the time derivative of the displacement in space - should only use speed.
I was wondering what the consensus in the physics community is about this/
Your car speedometer has no negative value but the car can reverse.
Physicists prefer speed for the speed scalar and velocity to mean a velocity vector. Laypeople use them intercchangeably. Decide based on your audience.
Aside question: Newton did not need the word speed, he used only the word velocity in Principia (translated). I wonder, did the special meaning of the word speed in physics originate in the 18th century (hydrodynamics), in the 19th century (kinetic gas theory), or in the 20th century (when people owned cars with a speedometer)?
Other languages like French and German don't have separate words for speed and velocity.
In Newton's day the vector idea was not well developed, and celerity was used for what we now call velocity and some of the modern uses of speed.
The term speed then meant 'fortune' as in God Speed which wished good fortune.
Today the term velocity should be used for a vector, although celerity is still available.
Speed, today, is a much more general term that does not even necessarily involve motion as in
A three speed bicycle
The speed of the bread dough rising
The speed of a camera shutter.
And many more.
It can also be used for the magnitude of the velocity vector. Like any magnitude it has no sign. A separate sign or backwards/forwards indication may be attached however.
Ok, the special use of the word speed in physics did not originate in Newton's time, the word celerity was used as well. However, the current convention among physicists to prefer speed for the magnitude of velocity presumably originated sometime and somewhere. When and where?
Found an answer: Gibbs
Thank you for the reference.
I believe that the word velocity originally from norman french.
  • · Replies 48 ·
  • · Replies 17 ·
  • · Replies 24 ·
  • · Replies 18 ·
