| New Reply |
Greens functions inspection method |
Share Thread | Thread Tools |
| Jun25-12, 04:31 PM | #1 |
Hi! A nice method for solving differential equations that occur in physics utilize greens functions as well as the fourier transform of the delta function to solve them partially by inspection. For example in electromagnetism Poisson's equation reads
[tex]\nabla^2 \phi = - \rho/\varepsilon_0[/tex] which can be solved by using the greens function [tex]\nabla^2 G(\vec r,\vec r') = \delta(\vec r-\vec r') = \frac{1}{(2\pi)^3} \int e^{\vec k \cdot(\vec r-\vec r')}d^3\vec k[/tex] where the right hand side is the fourier integral of the 3 dimensional delta function (integration is understood to be over all space). Now if we inspect the equation above one sees that [tex]G(\vec r,\vec r') = -\frac{1}{(2\pi)^3} \int \frac{e^{\vec k \cdot(\vec r-\vec r')}}{k^2}d^3\vec k[/tex] satisfies it. This is the 'inspection step'. Now by performing the integration one gets [tex]G = - \frac{ 1}{4\pi |\vec r - \vec r'|}[/tex] and by substituting back into [tex] \phi = \int G(\vec r, \vec r') (\frac{-\rho(\vec r')}{\varepsilon_0}) d^3\vec r' = \frac{1}{4\pi \varepsilon_0 }\int \frac{\rho(\vec r')}{|\vec r - \vec r'|} d^3\vec r'[/tex] one get the correct equation for the electrostatic potential. These kind of arguments inspired me to try the same thing out for one dimensional equations like for example [tex](\frac{d^2}{dx^2} + 1)f(x) = \frac{1}{sin(x)}[/tex] Using the same procedure [tex] (\frac{d^2}{dx^2} + 1)G(x,x') = \delta(x-x')= \frac{1}{2\pi}\int e^{ik(x-x')}dk[/tex] inspection indicates that [tex]G(x,x') = \frac{1}{2\pi}\int\frac{ e^{ik(x-x')}}{1-k^2}dk[/tex] But solving this equation by complex contour integration I get an imaginary greens function which is nonsense. Specifically I did it like [tex]G(x,x') = \frac{1}{2\pi}\int\frac{ e^{ik(x-x')}}{1-k^2}dk = \frac{1}{2\pi (x-x')} \int_{-\infty}^{\infty} \frac{e^{iy}}{1-(\frac{y}{x-x'})^2}dy = \frac{2 \pi (x-x')}2\pi i = \frac{i}{x-x'}[/tex] which would give a solution [tex]f(x) = i \int \frac{1}{x-x'} \frac{1}{\sin x'} dx'[/tex] I see that we get some problems above with divergences when x=x', however I do not see that we do _not_ get these problems in the higher dimensional examples. So the question is if it's something special with my electromagnetic example above or numerous other examples (from physics) which allows them to be solved by this method? And what is it about the one dimensional example above which does not allow it to be solved by this method? Is there some way that allowes it to be solved? |
| Jul7-12, 07:45 PM | #2 |
[tex]\int_\gamma dk \, f(k)[/tex] where [itex]\gamma[/itex] has several parts: 1) goes along the real axis from [itex]-R[/itex] to [itex]-1-\epsilon_1[/itex], 2) is a ccw semicircle of radius [itex]\epsilon_1[/itex] about [itex]k=-1[/itex], 3) along the real axis from [itex]-1+\epsilon_1[/itex] to [itex]1-\epsilon_2[/itex], 4) a ccw semicircle of radius [itex]\epsilon_2[/itex] about [itex]k=1[/itex], 5) along the real axis from [itex]1+\epsilon_2[/itex] to [itex]R[/itex], and 6) is a ccw semicircle of radius [itex]R[/itex]. Take limit as [itex]R\rightarrow\infty, \, \epsilon_1\rightarrow 0,\epsilon_2\rightarrow 0 [/itex] and use residue theorem. I end up with, [tex]G(x,x') = \frac{\sin( x' - x)}{2}[/tex] I may have made a mistake, but at least this may help. jason |
| Jul11-12, 04:12 PM | #3 |
[tex]f(x) = \int_a^b \frac{\sin(x-x')}{\sin x'} dx' = \left[\sin x \ln(\sin x') - \cos x x'\right]_a^b[/tex] if I now chose a = x then this produces the correct answer. However I am unsure of an argument on how to choose the suitable integration limits. The method seem to produce correct special solutions, but not without somehow setting x=x'. |
| New Reply |
| Thread Tools | |
Similar Threads for: Greens functions inspection method
| How to use Greens functions to solve variation of Helmholtz equation !? | General Math | 0 | ||
| Help with Greens functions | Differential Equations | 1 | ||
| Greens functions and density of states | Atomic, Solid State, Comp. Physics | 4 | ||
| Greens Functions, PDEs and Laplace Transforms | Differential Equations | 1 | ||
| [SOLVED] Greens Functions | Calculus & Beyond Homework | 5 | ||
