Prove: |a-b|≤|a|+|b| using Definition of Absolute Value
The discussion proves that for any vectors a and b, the inequality |a-b| ≤ |a| + |b| holds true using the definition of absolute value. Two cases are considered: when both vectors are either positive or negative, and when they have different signs. In both scenarios, the relationship is established by analyzing the expressions for |a-b| and |a| + |b|. This proof confirms the triangle inequality for absolute values in vector spaces.
  • Understanding of vector notation and operations
  • Familiarity with the definition of absolute value
  • Basic knowledge of inequalities in mathematics
  • Experience with case analysis in proofs
  • Study the triangle inequality in more advanced mathematical contexts
  • Learn about vector spaces and their properties
  • Explore the implications of absolute value in real analysis
  • Investigate other proofs of the triangle inequality using different mathematical approaches
Mathematics students, educators, and anyone interested in understanding vector properties and inequalities in mathematical proofs.
eme_girl
Prove that for any vectors a and b, |a-b| is less than or equal to |a| + |b|
I'm kind of lost, b/c i can't see a case where |a-b| would actually result in a value being less than |a| + |b|.
I've tried doing a proof that is similar, and when I was taught, the definition of absolute value was used to prove it.
|x|>|y| if and only if |x|^2 > |y|^2
square both side and you will see the relationship
Let a and b be any vectors. By the definition of absolute value, |x| is equal to x if x is greater than or equal to 0, and -x if x is less than 0. Therefore, |a| is equal to a or -a, and |b| is equal to b or -b.
Case 1: a and b are both positive or both negative
In this case, |a-b| is equal to a-b or -(a-b), and |a| + |b| is equal to a+b or -(a+b). Since a-b and a+b are both positive, it follows that |a-b| ≤ |a| + |b|.
Case 2: a and b have different signs
Without loss of generality, assume that a is positive and b is negative. In this case, |a-b| is equal to a-b, and |a| + |b| is equal to a-b. Again, it follows that |a-b| ≤ |a| + |b|.
Therefore, for any vectors a and b, |a-b| is less than or equal to |a| + |b|, which proves the statement.
  • · Replies 16 ·
