| New Reply |
A wire segment 1.2 m long carries a current I = 3.5 A |
Share Thread | Thread Tools |
| Jun27-12, 02:22 PM | #1 |
A wire segment 1.2 m long carries a current I = 3.5 A, and is oriented as shown in the figure. The +x-axis points directly into the page. A uniform magnetic field of magnitude 0.50 T pointing toward the -x direction is present as shown. What is the magnetic force vector on the wire segment? 2. Relevant equations Fm=Il x B l=1.2m h sin θ h cos θ 3. The attempt at a solution 1.2 sin 30° = 0.6m 1.2 cos 30°= 1.04m Fm= I | i j k | | 0 1.4m 0.6m | |0.5T 0 0 | =3.5 (0.3 j + 0.7 k) = 1.05 j + 2.45 k so thats my attempt... but is totally wrong, my answer is not near any of the options. Does anyone knows what am I doing wrong?? Thank you! |
| Jun27-12, 03:22 PM | #2 |
Does 1.2 sin (30) give you the y or the z component of the length?
Also, the direction of the length vector should be in the direction of the current. So, think about the signs of the y and z components of the length vector as well as the sign of the x-component of B. |
| Jun27-12, 04:04 PM | #3 |
the Y component i think... not?
got you on the direction! I missed that |
| Jun27-12, 04:14 PM | #4 |
| Jun27-12, 04:17 PM | #5 |
Thank you sooo much!!!!!!!!!!!!! :d
| Jun27-12, 07:18 PM | #6 |
Hello! So this is my lastest attemp:
Since I is a current in opposite direction, is -I (thanks Tsny!) i j k 0 -0.6 -1.03 0.5T 0 0 So: -3.5[(-0.6*0)-(-1.03*0)]i-[(0*0)-(0.5*-1.03)]j+[(0*0)-(-0.6*0.5)]k =-1.80j-1.05k This are the numbers, but not the signs... What am I missing? Thanks! |
| Jun27-12, 08:31 PM | #7 |
What is the sign of the x-component of B?
| Jun27-12, 08:34 PM | #8 |
Recognitions:
Also, your magnetic field strength should be -0.5i, since it's going in the negative x-direction (pointing directly out of the page). I would suggest also that you save the simplification till the last step - otherwise you get rounding errors with the [itex]\sqrt{3}[/itex], for example. You can check if your answer is in the correct orientation by using the right-hand rule. BTW, interesting username.
| New Reply |
| Thread Tools | |
Similar Threads for: A wire segment 1.2 m long carries a current I = 3.5 A
| About current/voltage reflection in a long coaxial wire. | Electrical Engineering | 2 | ||
| Charge of a segment of an infintely long wire | Introductory Physics Homework | 1 | ||
| Time-varying current in a long straight wire | General Physics | 5 | ||
| force, magnetic field, current, long straight wire | Advanced Physics Homework | 3 | ||
| Current, Voltage, Long Wire | Classical Physics | 6 | ||
