| New Reply |
Question about potential difference in circuit with resistance |
Share Thread | Thread Tools |
| Jun28-12, 01:12 AM | #1 |
Sorry for this post, but im desperate for an answer. Please reply thanks in advance
Consider a simple circuit composed of a battery whose ends are connected by a wire. The potential difference of the battery is Vbatt ohm's law gives: V=IR If the resistance of the circuit is ignored then the potential drop across the wire is zero. But using kirchoff's voltage law the sum of the potential difference in the loop must be zero,my first question is where does the potential drop? If the resistance of the wire is not ignored then there is a voltage drop equal to the potential difference of the battery.Even when the resistance is small approaching zero the voltage drop is still equal to Vbatt. The limit approached by the voltage drop as the resistance approaches zero is still Vbatt but the voltage drop when the resistance equals zero is zero by using V=IR. My 2nd question is why is it not continuous? Shouldn't the voltage drop still be Vbatt My third question is about a switch in parallel with a resistor and a battery. The resistance of the conducting wires is ignored. My professor said that if the switch is open then there is zero current passing through it and using V=IR the voltage across the switch is zero. Because it is in parallel with the resistor the potential difference across the resistor is also zero. but can't a switch be considered as a conducting material(air) with high resistance. The total resistance of the parallel combination of the switch and the resistor is approximately equal to just the resistance of the resistor by using the equation: (1/rs)+(1/r)=(1/rT) since the ratio (1/rs) almost vanishes because rs, the resistance of the switch is too big. But since there is a total resistance there must be a voltage across the resistor. Please reply |
| Jun28-12, 03:18 PM | #2 |
Mentor
| Jun30-12, 04:55 AM | #3 |
thanks for the reply.
I have another question. It is a voltage source(V) in series with a resistor(R1) and with the parallel combination of a diode and another resistor(R2). The image of the circuit is attached below. My professor discussed the same circuit and said that if the diode is reverse biased, it acts as an open switch and the voltage across R2 is equal to V. It is a lesson about clipper circuits. My book stated the same thing without explanation so i guess the reason must be simple. But i still don't get it. My attempt for an explanation is as follows: The diode becomes an open switch when reverse biased. An open switch has high resistance, and has a potential difference across it. This potential difference equals the potential drop across R2 because it is in parallel with the diode, VD=V2. Considering the loop containing V, R1 and the diode, by Kirchoff's voltage rule, V-V1-VD=0 or V-V1-V2=0. Now V=V2 if V1=0. Why is V1 zero?? Please reply. Thanks |
| Jun30-12, 04:58 AM | #4 |
I'll try to read my book again to see if this is really what it means to say? Sometimes the english really makes it difficult for me.
By the way , your replies were really helpful, thanks again!!! |
| Jun30-12, 05:22 AM | #5 |
Mentor
| Jun30-12, 03:00 PM | #6 |
Let me try and describe the circuit.. Lets assume the V in your circuit is 10V and R1=R2=1KOhm In your diagram the top end of the battery is shown as +ve. That means the diode will be forward biased = conducting. It's like a switch that it "ON". So replace the diode in the diagram with a wire! That means the current flowing in R1 will be I = (V-0)/R1 =10V/1000Ohms = 10mA OK so far? Now turn the diode around so it's "pointing" upwards. Now the diode is reverse biased = non conducting. This is like a switch that is "OFF" or open circuit. So you can remove the diode from the diagram because it is doing nothing. Now the current flowing in R1 is I = V/(R1+R2) = 10V/2000ohms =5mA The voltage on R2 is given by the "potential divider" rule.. V(r2) = V * R2/(R1+R2) So the voltage on R2 is NOT = V However if R1 is very small or zero then.. V(r2) = V * R2(0+R2) = V * R2/R2 =V and the voltage on R2 is equal to the battery voltage. R1 might be very small if it is intended to represent the "internal" or "source resistance" of the battery. Real batteries are not "perfect". They have a small internal resistance due to the way they are made. This is very small for a car battery but quite large for some AA batteries especially when nearly empty. |
| Jun30-12, 03:08 PM | #7 |
When you understand the above...
Consider what would happen if you built the circuit as it was drawn and R1 was only 0.1ohm? The diode is conducting so the current is given by I = (V-0)/R1 =10/0.1 = 100 Amps !! Most diodes would fail very quickly. So in most circuits R1 would not be small. |
| Jun30-12, 09:33 PM | #8 |
thanks
I went over my notes, my professor did use the voltage divider principle, sorry for the post. |
| Jun30-12, 09:43 PM | #9 |
Sorry to disturb you but i have another question.
What if there is a circuit consisting only of a 12v source and a 9v source If the batteries are ideal and i use Kirchhoff's loop rule it seems to show that 12V=9V?? I think i should take their internal resistance into consideration. Another question is when a 9v voltage source is connected in parallel with a silicon diode. KVl gives 9v=barrier potential=0.7V Am i missing anything? PLease reply. Thanks again I'm having trouble with my basic electronics course because in our curriculum it is to be taken at the same time with basic circuit analysis.I haven't even mastered circuits yet. |
| New Reply |
| Thread Tools | |
Similar Threads for: Question about potential difference in circuit with resistance
| Simple Question: potential difference between two points on circuit | Introductory Physics Homework | 6 | ||
| Need help with a potential difference/resistance/current problem | Introductory Physics Homework | 5 | ||
| [Circuit] Potential Difference question | Introductory Physics Homework | 4 | ||
| Circuit: Potential Difference | Introductory Physics Homework | 1 | ||
| Potential Difference, current, and resistance | Introductory Physics Homework | 3 | ||
